4inch Exhaust
75mm = 790 cfm = 359 hp 85mm = 1007 cfm = 458 hp 90mm = 1131 cfm = 514 hp
This means that for every cubic inch of incoming air, there is FAR more molecules than in one cubic inch of exhaust. This formula only applies to exhaust systems.
single 3" = 369 hp single 4" = 656 hp dual 2.5" = 512 hp dual 3" = 738 hp
Is this fwhp or rwhp?
for every hp produced the pipe needs to flow .4545.. cfm
1cfm=2.2hp
1127cfm=2479hp
I assume that formula holds true for only na?
Looking at the numbers a 4in pipe is absurd.
Revised my 3" exhaust to 4" (lost 2psi). Made a more efficient inlet hat and gained back the 2psi + 1 deg timing. Gained +58rwhp/+63rwtq
Figure roughly +40rwhp/+40rwtq without the degree of timing.
Same boost, more efficient, more power.
614rwhp/537rwtq to 672rwhp/600rwtq
https://ls1tech.com/forums/forced-induction/626013-procharger-346ci-58rwhp-63rwtq-new-inlet-hat-exhaust-1deg-timing.html
I would think you'd take into consideration the thickness of the material and subtract that from the OD. Figure for 16GA tubing you lose ~.130" (.065" wall thickness) of the cross section.
I'm only mentioning this because I was figuring out the same stuff not too long ago.
1cfm=2.2hp
1127cfm=2479hp
As far as what is the equivilent pipe diameter that the start to become a restriction...
Just like 3" True Duals is 3" + 3", 2 header collectors are 3" + 3".
Maybe I just misunderstood what you were trying to say. No big deal.
