Any write up's on Installation Of underdrive pulleys?
Old Dec 28, 2006 | 08:10 PM
Grimes's Avatar
try the oven def. not sure what you mean by notch?
Old Dec 28, 2006 | 08:13 PM
The PAT WS6's Avatar
what do i do if the oven method does not work? do you think it will?
Old Dec 28, 2006 | 08:19 PM
Grimes's Avatar
I think it will - but otherwise you will have to use the threaded rod tool to be safe.
Old Dec 28, 2006 | 08:26 PM
i have the rent a tool thing for auto zone but it aint working, it doesnt fit or im using it wrong.
Old Dec 28, 2006 | 09:27 PM
still no luck after heating it upo.
Old Dec 28, 2006 | 09:57 PM
KY Z28's Avatar
Ok so here is what I did...use this at your own caution. I couldnt get mine to start very much either and couldnt get the old balancer bolt to thread up at first. So, I put the pulley on as far as I could and placed a piece of metal across the face of it. I hit the piece of metal with a 5 lbs. sledge until it was on far enough on to put the bolt in and draw it up. Took about 2 minutes, worked like a charm.
Old Dec 28, 2006 | 10:16 PM
will attempted here again shortly
if no go, tomrw will bring plan B
Old Dec 28, 2006 | 11:58 PM
white_camaro's Avatar
for my first install i did the same thing you did ky z28. for the second install after the cam i used a longer bolt.
Old Dec 29, 2006 | 12:01 AM
oh yah dont worry to much about the 140 degrees, just use proper judgement and crank down the old bolt to 240 if you can, but 200ftlbs. should do, then go 37ftlbs with the new bolt and however many degrees you can get until it feels like its real tight.
Old Dec 29, 2006 | 11:40 AM
The Alchemist's Avatar
UNDER PRESSURE MOD
When you heat it in the oven, make sure it is around 250-275 degrees. A little higher won't hurt it either. You are heating it to get it to expand just enough to slip it over the crank snout. Whatever you do, take your time and don't try to force anything. I would not reccomend hitting it with anything because the crank and bearings will be taking all of that force which they weren't meant to. (Think spun or FUBAR'd crank bearing here). Also, don't strip out the threads either, that is a messy fix as well.
If heating it to that temp doesn't work, buy the tool listed here:
https://ls1tech.com/forums/removed-locked-thread-graveyard/391883-new-crank-dampener-installation-tool-pics.html
It is designed to pull to press the pully on, placing most of the thrust on the washer and not the threads.
Old Jan 6, 2007 | 02:19 AM
6LITEREATER's Avatar
Did you ever get it on?
Old Jan 10, 2007 | 05:50 PM
  #32
BitViper's Avatar
Hey DemonBird....you following me around?
I just bought one for my car.....
so ..did ya get it on?
Old Jan 11, 2007 | 09:15 AM
  #33
bigti99a's Avatar
i had to heat my powerbond up to get that bitch on good. check the cam install at installuniversity.com for a good write up on it. TAKE YOUR TIME. you dont want to strip any crank threads.
