Any write up's on Installation Of underdrive pulleys?
Old Dec 25, 2006 | 10:46 PM
The PAT WS6's Avatar
Default Any write up's on Installation Of underdrive pulleys?
Got this bad boy for xmas and need some input/tips on installing it.
any help would be appreciated.
Old Dec 25, 2006 | 10:49 PM
Magnet's Avatar
what brand is that?
P.S. i would like a write-up as well............
Old Dec 25, 2006 | 10:55 PM
powerbond 25%
Old Dec 25, 2006 | 11:40 PM
Grimes's Avatar
pretty much:
-put car in reverse (for manual)
-take stock belts off
-take off stock bolt with impact gun or breaker bar with pipe for leverage
-use three jawed puller to grab three inner tabs on stock pulley, and pull off
-heat up new pulley in oven to 200 deg
-slip on pulley and press on with old bolt, longer bolt, or threaded rod and nut/washer
-torque old bolt to 240 ft-lbs and then remove
-install new GM bolt and torque to 37 ft-lbs
-turn bolt additional 140° (torque to yield bolt)
-install shorter belts
-drink beer
https://ls1tech.com/forums/removed-locked-thread-graveyard/391883-new-crank-dampener-installation-tool-pics.html
fwiw, I was able to slide my pulley on far enough after heating it up so that I could grab at least 3-4 crank threads to pull it on. Threaded rod is the safest bet though.
Old Dec 26, 2006 | 06:29 AM
Big Budda's Avatar
All i can say is use threaded rod for the install..
It will save you a ton of headaches
Old Dec 26, 2006 | 03:45 PM
Steve Burger's Avatar
LS1TECH Sponsor
Heat it up for an hour or so. It will slip on so that you can get 6-8 threads of the old bolt in. Then torque it down and follow the procedure above for the new bolt.
Nice to see the oven method mentioned. I have done this about a dozen times. Works like a charm. Y'all did make fun of me when I posted this a few years back though.
Old Dec 27, 2006 | 02:12 AM
what does this rod bolt look like yall used to get the pulley back in? and what are my options on gettin this sucker back on there? do i have to get a new GM Bolt??
any more advice or tips would be great here i plan on doing this thursday or friday.
Old Dec 27, 2006 | 02:13 AM
and what are them 3 threads on my new pulley in the middle, with the holes.?
Old Dec 27, 2006 | 04:49 AM
Grimes's Avatar
That's what you use if you need to pull it off again. You have to use a different type puller.
Old Dec 27, 2006 | 05:12 AM
cakweems's Avatar
Good luck,hope you have better luck than i did,we broke two pullers trying to get that thing off,but after its off its a breeze.
Old Dec 27, 2006 | 12:28 PM
how much rwhp am i looking at with one of these bad boys on?
Old Dec 27, 2006 | 02:22 PM
BitViper's Avatar
Common thought is 5-8
Old Dec 27, 2006 | 04:23 PM
J E T's Avatar
http://www.bowlingss.com/Mods/Instal...e%20Pulley.mht
Old Dec 27, 2006 | 07:21 PM
do i need a new bolt????
Old Dec 27, 2006 | 08:10 PM
Magnet's Avatar
yes you need a new bolt...they are stretch to fit bolts, so after removed they arent the right size anymore
Old Dec 28, 2006 | 02:42 AM
sweet good thing i didnt dig into it tonight like i was goin to cus i was just goin to reuse the stocker, probably would of been racing and the damn pulley would of shot off at 150mph
Old Dec 28, 2006 | 08:23 AM
stealth71's Avatar
This tool is great for balancer installs: https://ls1tech.com/forums/showthread.php?t=391883
Might want to get an ARP crank bolt, then it can be reused.
Old Dec 28, 2006 | 03:04 PM
thanks for all the help guys i went to auto zone and rented a harmonic ballencer install kit which is very similar to that home made one, i also got the puller, im about to attempt it here in a few.
gthanks again
Old Dec 28, 2006 | 06:50 PM
having trouble installing the balancer, it wont slip on but 1/4 of an inch so im throwing it in the oven? will this work you thinkk to fix it.? ive been trying to find a longer bolt to do the job but i cant find it anywhere?!?!
its an m16 with a 2 pitch.
any help or advice would be great here! thanks.
Old Dec 28, 2006 | 07:12 PM
and wat is the lil notch instide of the pulley where it slides on? its like a key of some sort.? anyone?
