The Metal Intake Thread...
Old Jan 16, 2007 | 02:54 PM
  #41
WS6nJAX's Avatar
Restricted User
i went with the 80mm bbk and opened up the weiand inlet to match.
Old Jan 16, 2007 | 04:09 PM
  #42
6techniques's Avatar
Do you have any numbers/e.t.'s or anything? Im still doing research on this and the more numbers/e.t.'s the better!
Old Jan 16, 2007 | 06:16 PM
  #43
King Nothing's Avatar
which one is easier on install?? which one do you have the least mods to do to make it work? the BBk or the weiend?
Old Jan 16, 2007 | 06:47 PM
  #44
only reason i ask is cause i found both brand new for really good prices . . . but i'm gonna go with the one that is less of a pain in the *** as far as makin it work on my engine
Old Jan 16, 2007 | 11:12 PM
  #45
so which is better on a (FOR NOW) stock LS1 BBK or Lingenfelter?
Old Jan 17, 2007 | 08:55 AM
  #46
nyteryder167's Avatar
I just got my PP satin intake earlier this week. Looks like a real nice piece, very happy with the quality. I didn't get fuel rails with it but Professional Products is taking care of that. I will be installing it next week dynoing a few weeks after that so hopefully we'll have some numbers then. I'll post up some pics of it tonight.
Old Jan 17, 2007 | 10:10 AM
  #47
I would go with the BBK, Im not saying its better but that price isnt bad and you can still get the power youre looking for.
Old Jan 17, 2007 | 10:26 AM
  #48
TUCKZ28SS's Avatar
how much and where?
Old Jan 17, 2007 | 10:28 AM
  #49
TUCKZ28SS's Avatar
anyone got a price on the PP version their website doesn't have one on it
Old Jan 17, 2007 | 10:44 AM
  #50
Byunspeed has them, check their website. The price varies for satin finish, polished, what size opening, etc.
Old Jan 17, 2007 | 10:51 PM
  #51
dpw41285's Avatar
ok since i dont have my weiand at the apt and/or my dial calipers, how much can you open up the intake for a tb? 85mm or 90mm?? also how much better would a 80mm bbk flow than a p&p ls1. I really like the aftermarket throttle bodys and i will be selly my p&p tb
Old Jan 17, 2007 | 11:11 PM
  #52
chriswtx's Avatar
I don't see how you could open it up to 90MM. 80MM no problem. 85MM maybe....Maybe 90MM if some one made the same bolt pattern, but it would be close...
Old Jan 18, 2007 | 12:00 AM
  #53
dpw41285's Avatar
what bolt pattern is the holley? so your saying a 80mm bbk would be a nice touch. also the 80mm will outflow the stock p&p?
Old Jan 18, 2007 | 12:08 AM
  #54
chriswtx's Avatar
don't know. The bolt pattern is stock LS1/LS6 3 bolt. Most 90MM are LS2 4 bolt..BBK just released an 85MM as well. I have a 90MM ls2 throttle body I was going to try and make an adapter plate for it, but it doesnt look like it will work.
BBK...
https://ls1tech.com/forums/sponsor-sales-specials/639351-new-bbk-85mm-throttle-body.html
Old Jan 18, 2007 | 12:11 AM
  #55
dpw41285's Avatar
saw that, but you dont know if the mani can be opened that much?
Old Jan 21, 2007 | 06:39 PM
  #56
chriswtx's Avatar
I port matched my Weiand intake to my TSP LS6 stage 2.5 heads today. There was a big difference in the head runner and the intake runner. Most of the work was done to the upper and lower walls. The side walls were very close. I didn't do much on the plenum side, just took of some casting flashing...
Before....
After the porting..
Old Jan 21, 2007 | 06:57 PM
  #57
chriswtx's Avatar
also to add to this, I just matched up my template to my stock 241 head and noticed the even with a stock head the Weiand would benefit from porting. The Weiand in stock form blocks about 1/8" of the stock head's intake runners floor and about 1/16" of the top of the runner. It looks like the floor of the Weiand's runner is designed to be portmatched. It wouldn't take much to match the floor to the head..
Old Jan 21, 2007 | 07:52 PM
  #58
Chris, in theory, how much of a gain in hp/tq and cfm would you expect from this? Looks good, did you use a SA kit to do it?
Old Jan 21, 2007 | 07:58 PM
  #59
chriswtx's Avatar
I use a porting burr for aluminum to do the cutting/shaping and 80 grit sanding rolls to finish it out. Not sure on how much CFM you will gain, but from just looking at the port differences in the head and intake I would say there is a gain to be made...Probably not much on my blower motor, but on a NA motor for sure..
here's what my heads look like..
https://ls1tech.com/forums/forced-induction/633090-finished-up-my-new-heads-now-bottom-end.html
Old Jan 21, 2007 | 08:13 PM
  #60
nice, thats some good stuff to know!
