ORY bumping floor board (help)
Old Dec 28, 2006 | 05:34 PM
noxiouSS's Avatar
Default ORY bumping floor board (help)
just finished LT and ORY install. When i get on it the ORY hits the floor board my the drivers feet. Any solutions?
Old Dec 28, 2006 | 05:39 PM
cabech984's Avatar
poly motor mounts!
Old Dec 28, 2006 | 05:43 PM
BIG_MIKE2005's Avatar
95-LS1-HR Mufflex LS1 F-Body Y-Pipe Bumpstop Hanger for 3" y-pipes
$40.00
scroll down till you see it.
http://www.thunderracing.com/catalog...&vid=3&pcid=54
Old Dec 28, 2006 | 06:19 PM
GTObsessor's Avatar
$40.00
Cheap and easy but I personally wouldn't do that. I wouldn't want something holding it there so all 300+ Ft/lbs of my engine are torquing down on that pipe every time I stomp on my go pedal. It's not easy to change out the mounts but Poly mounts are exactly what you need to stop the y from banging the floor board.
Old Dec 28, 2006 | 06:25 PM
frank1986's Avatar
valve spring will work i had the same problem
Old Dec 28, 2006 | 06:32 PM
01FormulaTA's Avatar
I had the same problem when I did my LT install, first I took a pry bar and tried to bend the y-pipe...that gave me a little clearance but it still hit so I went and bought some heater hose and some stainless band clamps and slit the hose and wrapped the pipe where it was closest to the floor board to give it kind of a cushion and it did the trick, now I have been driving with it for about 8k miles w/ no prob and no banging and it only cost me like $10, hope this helps
-Chris
Old Dec 28, 2006 | 06:44 PM
BREWS02WS6's Avatar
-Chris
I did this too. Mine was banging over the axle so I bought header wrap from Advance, wrapped where it was hitting, and tied it off in 3 sections w/ some thin wire since thats all we had. No noise, and $10 or less!
Old Dec 28, 2006 | 07:57 PM
noxiouSS's Avatar
now it sounds like its hitting the driveshaft or something. It hits pretty hard.
Old Dec 28, 2006 | 08:10 PM
noxiouSS's Avatar
on your guys cars when you hit the gas did it only bounce once until you let off the gas? or did it keep hitting the whole time you were in the throttle?
Old Dec 28, 2006 | 09:25 PM
CAMAROZ28AQUINO's Avatar
Does the Ypipe hitting the floorboard actually cause retard timing and "cut much needed horsepower at the track" as stated in the thunderracing website?
Old Dec 28, 2006 | 09:37 PM
noxiouSS's Avatar
it feels jerky when it does it. like the power is sparatic.??
Old Dec 28, 2006 | 10:24 PM
noxiouSS's Avatar
ttt cause i need to know
Old Dec 28, 2006 | 11:53 PM
white_camaro's Avatar
on my friends car when his x-pipe hits the floorboard it bounces repeatedly, a lot of it depends on your engine rpms , how close the pipe is to the floorboard, and how bad your mounts are. id do the heater hose thing or the header wrap until you have the time and money to replace the mounts.
Old Dec 29, 2006 | 08:33 AM
Luna's Avatar
Heres my experience with y pipe banging. I tried all of the above solutions.
-Bending / readjusting the pipe helps, but in my experience did NOT solve the problem.
-The mufflex y hangar thing, helps, but again did NOT solve the problem completely.
-Poly motor mounts helped the most yet, but still didn't stop the banging completely
My final solution was the heater hose! It works great and have run it that way over 10k miles. I don't like it, but it works.
I think the reason I have had such little success with the other methods is because I have so little clearance in the first place (1/4")
Old Dec 29, 2006 | 04:58 PM
noxiouSS's Avatar
wont the heater hose melt on the y-pipe and start smoking?
Old Dec 29, 2006 | 05:03 PM
GT Griller's Avatar
I had my mechanic weld in a little peice of metal kinda like a support and it stoped it....it was free cause it took longer to put the car in the air than to actually do any work.
Old Dec 29, 2006 | 06:10 PM
jimmypop13's Avatar
Yes!!!
You need to buy some DEI header/exhaust wrap. Thunder Racing has a bunch of it and a sale goin on right now which is cool. wrap that around a few times where the y-pipe hits. Take two 2.5" hose clamps to each end of where you wrapped the pipe to hold the wrap in place. Then cut out a short piece of large heater hose, flatten out with a vice or somethin, and run 3" or 3.5" hose clamp through it. Now put that over the middle of the exhaust wrap and tighten the hell out of it. Go for a drive and get the exhaust hot. Then get back under and tighten down the middle clamp again as the heater hose will have gotten hot and bend a little more. If you don't retighten it, your middle clamp with the hose may spin upside down over time. Also, over time mine sometime slides out or the clamp eventually cuts through the hose. I like it TIGHT!!
This is how I did it and it works great. I hope this helps
oh yeah, I did have to use a large breaker bar though to bend down the pipe so I could squeaze the hose in there
Old Dec 29, 2006 | 07:31 PM
noxiouSS's Avatar
sounds good. thanks for the replies
Old Dec 29, 2006 | 07:40 PM
pSSycotic's Avatar
I beat the hell out of the part under the car where it hits. I hits sometimes at idle, but once i start going it usually stops
Old Dec 29, 2006 | 08:25 PM
noxiouSS's Avatar
what ever works
