LS6 Intake Gaskets
Old Dec 29, 2006 | 03:08 PM
FRCBobby's Avatar
Default LS6 Intake Gaskets
I just got an LS6 intake off of the board and it doesn't have any intake gaskets on it.
Will the ones from my old LS1 intake work?
Will the ones from Comp work?
Or would I just have to go with the GM ones?
Old Dec 29, 2006 | 03:15 PM
mondi2002's Avatar
The old ones will work if they are in good shape.
If not the cheepest I found for aftermarket is Napa.
Oems are expensive, the best price is at Fred Beans.
GM Part #12533587 (8pc set)
Old Dec 29, 2006 | 03:37 PM
FRCBobby's Avatar
You wouldn't happen to know the NAPA part number would ya?
Old Dec 30, 2006 | 08:16 AM
WILWAXU's Avatar
The GM Part number for the kit is: 12533587
Old Dec 30, 2006 | 12:34 PM
SweeTbone's Avatar
I agree. I re-used mine when I did my swap at 54,xxx miles. As long as you are careful when pulling them off your old intake you're good to go.
Old Dec 30, 2006 | 01:14 PM
FRCBobby's Avatar
Sounds good I just didn't want to order them if I could use what I already had.
Or if the COMP ones would work, does anyone know if they will?
Old Dec 30, 2006 | 03:19 PM
blkbird's Avatar
I picked up a set from Oreillys for about $25.
Old Dec 30, 2006 | 04:30 PM
Yousif Q8's Avatar
New GM it's ok because i had problem when i was re-used mine
Old Dec 30, 2006 | 04:56 PM
Hodgesz28's Avatar
Good thread I was wondering the same thing! Thanks
Old Jan 2, 2007 | 07:23 AM
mondi2002's Avatar
Its NGAMS16350. All you do is search for Non-Napa part #
on there site and enter the GM Part #.
http://www.napaonline.com//MasterPag...ake)+-+Hi-Perf
Old Jan 13, 2007 | 01:30 PM
FRCBobby's Avatar
Thanks.
I got the old ones off and put them in place and just didn't like the way they looked so I am going to be calling NAPA on Monday and get me a set on order.
Old Jan 13, 2007 | 05:54 PM
DOUBT IT's Avatar
You can get the Fel-Pro at Advance for $19 or so. That's what I used.
Old Jan 13, 2007 | 06:56 PM
TheBlurLS1's Avatar
That's what she said...
BYUNSpeed also sells a port gasket kit, says it's for the FAST, but I've heard it's the exact same ones as the LS1/LS6.
Old Jan 13, 2007 | 10:56 PM
FRCBobby's Avatar
Do you have the part number for the Fel Pro? I could either get them at Advance or have them ordered and in by Monday.
Thanks
Old Jan 13, 2007 | 11:48 PM
blkbird's Avatar
Oreillys had them in Felpros stock.
Old Jan 14, 2007 | 12:24 AM
bww3588's Avatar
i got my Fel-Pro's from jegs
375-MS92438
375-1312-3
these are the 2 part numbers for the 2 different designes.
Old Jan 14, 2007 | 10:45 AM
FRCBobby's Avatar
Which design would be needed for the LS6? Or does it matter
Old Jan 14, 2007 | 10:49 AM
matt94z's Avatar
Same here
Old Jan 14, 2007 | 12:55 PM
Sh4Dy's Avatar
375-MS92438 = LS1/LS6 and FAST Intake Manifolds
375-1312-3 = Wiend Intake Manifold
