Fabricated Valve Covers
Old Aug 16, 2010 | 08:23 PM
01SOMSS!'s Avatar
Originally Posted by Brian @ KYTP
Several issues if you plan on running these:
1. Stock length plug wires DO NOT WORK with these valve covers.
2. One of the hoses for the air condition will not let you put on the coil packs on passenger side.
3. Stock oil dipstick and tube has to be bent away from the head to make it work on the passenger side.
i ran into every single one of these issues. they also leak oil. i called the place i got them from and I'm getting them exchanged for a new set. so how did everyone run these? i pluged the tb and manifold and ran a k&n filter on the filler hole. the 1st coil is in the way of the filter so I'm thinking about relocating them.
thanks!
