Question about exhaust pipe sizing formula (math)
Old Jan 2, 2007 | 04:03 PM
senicalj4579's Avatar
Default Question about exhaust pipe sizing formula (math)
I know exhaust pipe sizing is = PI x R x R = Area x 115 CFM / 2.2 CFM Per HP
but is this the same formula you would use for the header primaries?
Old Jan 3, 2007 | 07:58 AM
it must be the math lol
Old Jan 3, 2007 | 08:35 AM
Ragtop 99's Avatar
I've seen header primaries calculated using a formula that accounts for rpm and displacement to calculate the length and diameter.
Old Jan 3, 2007 | 11:13 AM
do you know how the formula goes? or do you just know theres a formula?
Old Jan 3, 2007 | 11:19 AM
lsx24's Avatar
I've seen that formula somewhere too, but I don't know what it is. Fwiw the formula you quoted will calcualte the potential flow rate, but it will not calculate the optimal header dia and length.
Old Jan 3, 2007 | 12:34 PM
Ragtop 99's Avatar
Per a post by J-Rod:
The formulas I have are:
Header pipe length (in inches) = ((850*(360-EVO))/RPM – 3
Header diameter (in inches) = ((cylinder. disp. * 16.38 / ((hdr len + 3) * 25))) * 2.1
EVO - Exhaust Valve Opens (gross)
These formulas are from A. Graham Bell’s Performance Tuning in Theory and Practice.
For a street engine, the RPM used should be the peak torque RPM. For a race engine, the peak hp RPM should be used. I find that the peak tq numers to be insanely long. So, I use peak HP.
Other possible links:
http://www.headerdesign.com/login/header.asp
http://www.popularhotrodding.com/en..._exh/index.html
http://www.popularhotrodding.com/en...h/photo_04.html
There is a software called pipemax which I've seen recommended to.
Old Jan 3, 2007 | 12:45 PM
V6 Bird's Avatar
Google Pipemax software. that will tell you everything you ever needed to know.
Old Jan 3, 2007 | 12:58 PM
very good stuff thanks.
