FAST Intake & evap solanoid question
Old Jan 5, 2007 | 07:42 AM
Michael02hawk's Avatar
Default FAST Intake & evap solanoid question
I just installed the FAST, and as documented by FAST there is not a provision on the intake for the evap solanoid bracket.
So what does everyone do, just let the solanoid lay there along side the intake/valve cover? Kinda sloppy in a way.
Old Jan 5, 2007 | 07:47 AM
brad8266's Avatar
Krazy glue.
Old Jan 5, 2007 | 08:19 AM
RedWS6 00's Avatar
I just kind of left it there, resting, its not going anywhere. Its not a clear picture of the evap, but you an just see it there. I guess you could alwas use a cable tie to keep it from moving.
Attached Thumbnails FAST Intake & evap solanoid question-enginebay_20060730.jpg
Old Jan 5, 2007 | 09:17 AM
bczee's Avatar
If you don't want to leave it hanging, Just use the old bracket to fab up a new one by welding some flat or round metal stock that will bolt to either the fuel rail or Coil mounting bolt.
Old Jan 5, 2007 | 09:35 AM
jmm98LS1's Avatar
Just relocate it like this:
https://ls1tech.com/forums/appearance-detailing/328151-evap-relocation-how-pics.html
I did it, only took like 10 minutes.
Old Jan 5, 2007 | 01:23 PM
DirtyJohn's Avatar
Mines just sitting there, I put some 5/16 rubber fuel line in place of the stock hose tho.
I think it looks better and has shiny metal clamps.
Old Jan 5, 2007 | 03:59 PM
SS1875's Avatar
Good old black zip tie to the fuel rail.
Old Jan 5, 2007 | 05:10 PM
Demonicbird00's Avatar
i installed my Fast 90/90 last nite, and i just left it in the stock location, its not going anywhere.
i did however run in to the TB parts. i got the 5 bolts for the TB to intake but they didnt give me a long enough bolt for the top TB hole. all is fixed now tho.
-brandon
