Fernco Mod
Old Apr 12, 2007 | 03:42 AM
  #81
99blancoSS's Avatar
The correct size would be a 3x4. I have a 3x3 sitting here and mo way I'll use it. I'd like a hump hose but I'm not paying what they want for them now. I'll go back to the original factory bellows if I have to. I like the SLP bellow but and not paying $60 for it.
There are other options out there. From the turbo crowd there are plenty of silicone couplers with humps as well. Its just finding a 3"x4" that comes in black and is not too stiff. There is a compnay in China I'm trying to hook up with to produce an inexpensive alternative to the SLP smooth bellow.
Old Apr 12, 2007 | 08:54 AM
  #82
Redlinez's Avatar
No, the 3/4 won't work. It really needs a 3x3.5. The 4" end on the TB is huge and sloppy. I got mine on, just took some coercing.
Old Apr 12, 2007 | 09:04 AM
  #83
Infantrymarine's Avatar
Did mine yesterday. Was easy after you boil it. Haven't noticed anything yet, performance or damage!
Old Apr 12, 2007 | 07:17 PM
  #84
gillbot's Avatar
I used a Y fitting and cut the leg of the Y off. It has a slight bend so it fits better and was the perfect size. The guy at lowes thought I was nuts when I asked to take 4 or 5 different ones out to my car to see which one would fit best.
Old Apr 13, 2007 | 03:55 PM
  #85
Danger731's Avatar
^ ha ha
Old Apr 13, 2007 | 04:15 PM
  #86
89Formulaws6's Avatar
the 3/4 is the one i have you just gotta do some trimming on the 4in part and clamp it down tight and it fits perfect
Old Apr 13, 2007 | 05:58 PM
  #87
99blancoSS's Avatar
stock size bellow is 3.5x4
Old Apr 18, 2007 | 06:32 AM
  #88
Danger731's Avatar
I used 3 x 3 boiled for 30 minutes, fit supernice.
Old May 15, 2007 | 09:15 AM
  #89
LS1rulz's Avatar
So what did you do to seal the opening?
Old May 16, 2007 | 03:47 PM
  #90
gillbot's Avatar
There is no opening to seal, I cut off the short leg of the Y and used that.
Old May 17, 2007 | 11:58 AM
  #91
Fifedogg's Avatar
no bellow is going to give any HP increase. I installed the SLP on on my car and couldn't notice a thing. The SLP has a better fit and won't break the lid like the Fernco because its made to flex. Not worth it in my opinion.
Old May 17, 2007 | 01:44 PM
  #92
coolformula's Avatar
I tried 2 different times with the Fernco and my knife and custom fitting and tried over an hour out the sun. I twas not possible to get it to fit, even got a frined to try, its a pain. I'm getting a used slp one. Not worth your time and gas and 5 dollars it costs.
Old May 17, 2007 | 05:25 PM
  #93
Dex's Avatar
Dex
What are you guys doing to make this so hard. I cut mine to fit with a cut off wheel then put it in the microwave for about 2 minutes and it went right on no hassles.
Old May 17, 2007 | 07:16 PM
  #94
LS1rulz's Avatar
So it easily comes off and back on now when you have to remove your air filter, or clean it, etc?
Old May 17, 2007 | 08:18 PM
  #95
rich Z's Avatar
I once bought this mod and thru it away since it wouldn't fit and have heard of cracked lids from it.
Old May 19, 2007 | 08:07 AM
  #96
gillbot's Avatar
I've put one on MANY cars without a single issue and have yet to see a single cracked lid.
Old Jul 19, 2007 | 03:11 AM
  #97
GMmexican's Avatar
sorry 2 ressurct an old thread i just bought my 3x3 fernco.......i will give it a few heat cycles
Old Jul 19, 2007 | 03:20 AM
  #98
Havok2's Avatar
ok, so whats the point off bringing up this thread? to say you bought one?
Old Jul 19, 2007 | 11:27 AM
  #99
GMmexican's Avatar
and to share my experience.........and 2 be one of the lucky ones that doesnt get a cracked lid
Old Jul 19, 2007 | 12:02 PM
  #100
jimmypop13's Avatar
i have a NW90 throttle body and an 85mm lid with an 85mm maf.
I'm still using the stock bellows because they still fit, but just a hair tighter.
If I went the silicone route just to make it look better under the hood, I'm wondering if I would just get a straight 4" hose about 6" long and just trim it from there. I need to measure that sh*t!
By Brett Foote | 2026-06-04 05:00:17
