SS autochrome (ebay) Y pipe
Old Jan 9, 2007 | 08:06 PM
marthastewart's Avatar
Default SS autochrome (ebay) Y pipe
Well I finished installing the e-bay headers last night. Took me 4 1/2 hours by myself. It was a much easier install than I thought it would be. Hell the hardest part for me was the #8 plug and wire. The only fitment issue I had was the Kmember was just touching a little. I took a torch and bent the lip in/up about 1/4 of an inch and its good to go.
As far as the y-pipe for these I made a custom one from 2 high flow cats and an elderbrock 3" y-pipe. The y pipe was not even close to fitting but I did not care, all I wanted was the 3" pipe with bends that were close. Took me about 4 hours to fab up this and install it. Its not perfect but I guess for the $199 I have invested in that pipe, cats, and clamps, I cant go wrong.
Here are a few pics, and my welding is by no means pretty, but it gets the job done. I was actually sick of working on this. Some day I will grind this down, paint it, and have it tucked up a little better.
Attached Thumbnails SS autochrome (ebay) Y pipe-clearence1.jpg   SS autochrome (ebay) Y pipe-clearence2.jpg   SS autochrome (ebay) Y pipe-header-ypipe.jpg   SS autochrome (ebay) Y pipe-yfinished.jpg
Old Jan 9, 2007 | 08:11 PM
Tainted's Avatar
woo we can be the e-bay twins
Old Jan 9, 2007 | 08:18 PM
00slowredz's Avatar
do you know how much the ory without cats are from the seller you got the y pipe from? if so, can i have the seller id?
Old Jan 9, 2007 | 08:19 PM
Tainted's Avatar
the sponsors are bound to have the eldebrock headers and y pipe its not an e-bay item but the SS headers are
Old Jan 9, 2007 | 10:04 PM
dpw41285's Avatar
was that a gas-less welder?? tainted you used jet hot y and worked well didnt it??
Old Jan 9, 2007 | 10:11 PM
Tainted's Avatar
worked excellent, but he used a different Y pipe. I got pics in my other thread that shows how well it fits
Old Jan 10, 2007 | 09:20 AM
I knew that I would be cutting up the Y to put the cats in so I wanted to get the cheapest one I could find. If I did not want cats, I would have went with the jet hots for a direct bolt up.
Yes it was a gas less mig. Some time in the future I will tuck it up a little further and clean all those welds down and paint it. Driven it for 2 days now and has not scraped at all.
Old Jan 10, 2007 | 10:12 AM
GR33N GoblinM6's Avatar
what cats are those? CATCO?
Old Jan 10, 2007 | 10:17 AM
9t8z28's Avatar
Why did you use cats with air tubes?
Old Jan 10, 2007 | 03:08 PM
dpw41285's Avatar
its hard to make gassless pretty, but if it works and you did it and it was cheap....all for it
Old Jan 10, 2007 | 03:11 PM
Tainted's Avatar
not much point in maknig it pretty anyhow unless you love showing off your underbody
Old Jan 10, 2007 | 05:27 PM
SuperSlow02's Avatar
sure you can....turn up the heat and a buffer, kinda looks like an arc weld
Old Jan 11, 2007 | 01:47 AM
Yes, they are catco's. I got them withthe air tube because they were the cheapest ones I could find. I put them in to keep the gas smell down a little and to cut back on the noise. At idle and cruse it is fairly mello. At WOT it friggen screams. I like!
