How the hell do you remove the last header bolt on passenger side?!
Old Jan 20, 2007 | 04:18 PM
W105's Avatar
Default How the hell do you remove the last header bolt on passenger side?!
To save the life of me I cannot figure out how to get a wrench on this last bolt. I've spent as much time trying to get this bolt off as I have taking the rest of the stock exhaust off. Someone please give me some insight on how to remove this passenger side header bolt all the way back near the firewall!
Travis
Old Jan 20, 2007 | 04:20 PM
RA4926's Avatar
i got under the car with an open end wrench and had my way with that little bitch. that also how i did the last spark plug and new header bolt on the passenger side.
Old Jan 20, 2007 | 04:34 PM
DirtyJohn's Avatar
Go at it from underneath..
Remove the heat shielding panels from that side
Lie on back with head toward rear of car, feet towards front obviously..
Use right hand and either a 10mm (or is it 8mm, I forget) gear wrench or socket
From that angle you should have plenty of room, I think...
Thats how I did it.
Old Jan 20, 2007 | 04:37 PM
W105's Avatar
Going to try that now, thanks guys!
Old Jan 20, 2007 | 04:39 PM
TheBlurLS1's Avatar
That's what she said...
10mm gear wrench if you don't have a compressor.
I have a 1/4" drive air-ratchet with 10000000 accessories for it. I can change the spark plugs from the tail pipe. That tool allows me to remove EVERY header bolt in about 30 seconds. It fits everywhere under the hood, and if it can't I can put some 1/4" wobble-extensions and U-joints on it.
ski23's Avatar
yup from under the car. i believe i used my ratcheting wrench
Old Jan 20, 2007 | 04:59 PM
steveo346's Avatar
i just removed the coil packs on the bracket and with a 10mm wrench
Old Jan 20, 2007 | 05:11 PM
TchargedLS1TA's Avatar
What he said.. Just remove the coil packs and it makes life easier. BTW, while you're doing that, might as well change you plugs at the same time
Old Jan 20, 2007 | 05:36 PM
LILWS6's Avatar
I was under the car with a 10mm ratches wrench and maybe a swivel head ratchet i used one of those two. to put it in with the headers tho i had to do it from up top and i never removed any of the coils.
Old Jan 20, 2007 | 05:41 PM
ErikElvis's Avatar
I got it from the top. I was a bitch and the socket wrench decided to get jammed between the bolt and a plastic thing and nothing would move
Old Jan 20, 2007 | 06:27 PM
RrCoX22's Avatar
i got it from the top too... long arms come in crucial
Old Jan 20, 2007 | 06:45 PM
02SOMWS6's Avatar
pop off your coil packs and get it from the top. 10 mm for both
Old Jan 20, 2007 | 07:04 PM
FU_I_AM_UltraZ's Avatar
Veteran: Marine Corps
yeah... underneath
Old Jan 20, 2007 | 07:41 PM
scotts94_z28's Avatar
did it from the top, real easy with the coils off
Old Jan 20, 2007 | 09:06 PM
RA4926's Avatar
undid bolt from the top = long skinny girl arms. undid blot from the bottom = average length manly arms
Old Jan 20, 2007 | 09:12 PM
W105's Avatar
Thanks for the help guys!
I did have to grind the casting tab on the block though..Pacesetters.
Old Jan 20, 2007 | 09:15 PM
98Camarod's Avatar
That tab was in my way too, I just beat the floor in.
Old Jan 20, 2007 | 09:16 PM
TransAminal's Avatar
Craftsman gear ratchet FTW
Old Jan 20, 2007 | 09:34 PM
ryle's Avatar
+1 for 10mm gear wrench
damn thing is a lifesaver!
Old Dec 17, 2021 | 04:52 PM
Jacobschevy's Avatar
I have the same issue but i have to drill that bolt out so im essentially fucked
