Quick Header question
Old Jan 30, 2007 | 08:10 PM
5PONT7's Avatar
Default Quick Header question
So if I get a set of Pace Setter LT Headers. Will I need to get a new Y-pipe or will it fit with my stock one?
Old Jan 30, 2007 | 08:14 PM
NiCks Ws6's Avatar
yes. you need a new one, with any LT set up.
Old Jan 30, 2007 | 08:15 PM
NiCks Ws6's Avatar
just grab the pacesetter y-pipe. fitment is excellent.
5PONT7's Avatar
What should I get with the Pace Setter LTs? I have the SLP LM on it now
5PONT7's Avatar
the off road one or the one with the CATS on it?
Old Jan 30, 2007 | 08:20 PM
agrV8dta's Avatar
Yes you will need to get a 3in ory or catted y. Unless you plan to keep the stocker, then I'm sure an exhaust shop can reduce down from the header which is 3 inch to the stock y which is 2.75 inch-or close to it.
Old Jan 30, 2007 | 08:23 PM
agrV8dta's Avatar
If emissions arent an issue in your area, then you can get either. Having cats on the car helps with the rasp you WILL have with that set-up.
Old Jan 30, 2007 | 08:25 PM
NiCks Ws6's Avatar
it depends on what kind of sound your looking for. if your young and want to be annoying as can be with your LM id get the ORY. if you want a more controlled (but still loud as hell with your LM) cleaner sounding exhaust note. then grab the catted y or ditch the LM completly.
Old Jan 30, 2007 | 08:27 PM
5PONT7's Avatar
well im not gona ditch the LM cause i just got it, but the Catted y is mad expensive.
Old Jan 30, 2007 | 08:36 PM
NiCks Ws6's Avatar
me personally. im looking for the loudest, meanest soundin exhaust w/o TD's that i can find. thats why i got the LM. but if you get the ORY you can always add cats later on.
Old Jan 30, 2007 | 08:48 PM
5PONT7's Avatar
sadly VA has an anti-ORY policy
Old Jan 30, 2007 | 08:57 PM
agrV8dta's Avatar
Catted y FTW!!!
Old Jan 30, 2007 | 09:13 PM
5PONT7's Avatar
Can i use my stock CATS with the Pace setter ORY?
Old Jan 30, 2007 | 09:32 PM
Starz T/A 17's Avatar
No the stock cats would be almost impossible to get on a 3inch Y pipe.... and FWIW every state has a anit ORY policy but that really doesnt stop anyone
Old Jan 31, 2007 | 03:45 PM
5PONT7's Avatar
What if i just got the SLP 3" Y?
Old Jan 31, 2007 | 03:58 PM
dpw41285's Avatar
ok let me break it down for you. ory with loud mouth will sound like ***. a catted y will sound better but will cost you more. ory is the preferred but with you exhaust choice is a no no. check out www.ls1sounds.com you are doing the right thing now and REASEARCHING before purchasing. you can also have you exhaust shop build you a y with carsound cats!!!
Old Jan 31, 2007 | 07:01 PM
5PONT7's Avatar
Yeah that does suck but i LOVE my LM so i dont think im gona change that.
Old Jan 31, 2007 | 07:10 PM
5PONT7's Avatar
So bottom line what do i need to do to get Pacesetter LT headers to work with my LM?
Old Jan 31, 2007 | 07:20 PM
blue99SS's Avatar
Here, get this. Pacesetter's and a Catted Y at a combo price.
http://www.texas-speed.com/shop/item...id=181&catid=8
Old Jan 31, 2007 | 07:21 PM
blue99SS's Avatar
Also, you will need those O2 extensions and a tune to delete the rear O2's.
