Filter Mag???
I haven't researched it yet, but does anyone use one? It's essentially a magnet that clamps onto the oil filter. At a minimum, I have a magnetic drain plug on all of my cars. Luckily, LS1 F-bodies have that from the factory.
http://www.filtermag.com/
PDF article
http://www.filtermag.com/carcraft.pdf
PDF article
Seems like kind of a gimmick to me, shouldnt the filter you use pick up most of the metal going through your oil system? And if the filter can't catch it will the metal pieces really be big enough to do a whole lot of damage. They make one for the fuel filter too, are there really metal pieces in the fuel tank that need to be picked up?
I don't think so.
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Good filter, frequent oil changes, are the best....although, these products are extra protection..thought about getting one, and then forgot...may still pick one up one day.....
engines will always have friction. extra insurance isnt a bad thing, besides even if you change your oil frequently. you dont get every ounce of the old out.
Originally Posted by TransAm12sec
I haven't researched it yet, but does anyone use one? It's essentially a magnet that clamps onto the oil filter. At a minimum, I have a magnetic drain plug on all of my cars. Luckily, LSxs have that from the factory.
PDF article
PDF article
well... remember the LS1 is an aluminum block/heads... alum. shavings aren't magnetic, so there is no need for that unless you got an iron block.
