dual exhaust Question
(ie need cats!) I have FLP long tubes
. I have FLP's with a Lanes 2.5" true dual setup all the way out the back. You are looking at anywhere from 400-1200$ depending on what type of material, style, brand...ect. Also the cheaper setups dump prior to the rear axle instead of going either over or under. I suggest going all the way out the back if you want to appear totally legal. Dumps are just a dead giveaway that you are running non-legal. It will just be $$$$.
They are a nice piece though, that is why. Trending Topics
I bet that there may be a difference, but it was like I said before. Probably nothing you are going to notice/hear. A dynojet may tell you, but deep down inside you know that you want a faster car, and not a number laying dyno *****.
You will gain tq with true duals. They scavenge more than ypipes, so you will have a thicker midrange than a ypipe setup, and depending how restrictive your ypipe setup is, you'll gain some hp.
You can run cats and headers with the Bassani. Just a small adjustment needs to be made, which any exhaust shop can do for you.
