intake manifold
Old Feb 9, 2007 | 01:38 AM
SoCal_T/A's Avatar
Default intake manifold
ok so what im curious about is im shooting for somewhere in the 720 rwp range and im wondering if i can get away wit using a ls6 manifold or if i need to step up to like a fast 90/90 set up
Old Feb 9, 2007 | 02:15 AM
TheBlurLS1's Avatar
That's what she said...
You can use an LS6 intake manifold......... as long as you've got about 15psi pushing it's way through it and into a 408....
How about a little more info on your setup?
Old Feb 9, 2007 | 06:52 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Casey, he has to be charged. This is gonna be another one of those "How to make 11'ty billion horsepower DD" threads.
If you are serious about power. Sheet metal intake.
Old Feb 9, 2007 | 09:02 AM
SoCal_T/A's Avatar
by no means is this one of those threads. i dont plan to dd the car. i was looking into a 383 with an F1a and good set of afr heads with about 15 psi. id be happy with round 500 rwp in my weekend cruiser then just have the 722 rwp when its just not enough
Old Feb 9, 2007 | 09:16 AM
lsx24's Avatar
Sure you can get away with using the ls6 intake manifold, you will just be leaving horsepower on the table.
Old Feb 9, 2007 | 09:20 AM
ClemsonT/A's Avatar
Max effort on a full drag car then get a sheet metal intake. Otherwise if you are spending 15k going forced induction get the 90/90 set up. IMO if its a weekend cruise car then 700hp is a lot even for that.
Old Feb 9, 2007 | 10:39 AM
HAMRHEAD's Avatar
You can look at getting a ported LS2 manifold as well if your going FI. Some people have had issues with the Fast intake and high boost.
Old Feb 9, 2007 | 11:27 AM
SoCal_T/A's Avatar
what kind of issues? how much would a ported ls2 run me?
Old Feb 9, 2007 | 11:30 AM
BlackSVT03's Avatar
Never heard feedback on the F-bodys, but couple friends have LS6 FAST intake manifolds on their GTOs and one friend has had fitment issues and his had a little leak because it wouldnt seal properly.
Old Feb 9, 2007 | 11:34 AM
amsterdamn's Avatar
This FI Firehawk has an Victor Jr intake with aluminum elbow and makes 715rwhp on 93 octane. It works well and is more affordable than a custom made sheet metal intake or Fast 90.
Old Feb 9, 2007 | 11:40 AM
amsterdamn's Avatar
Then again, this turbo Formula made 995rwhp with a LS6 intake.
Old Feb 9, 2007 | 11:42 AM
SoCal_T/A's Avatar
ok so as far as skimping on the intake should i step up to a 90/90 or just stay with what i got
Old Feb 9, 2007 | 11:46 AM
amsterdamn's Avatar
The cost of a Fast 90/90 is not justified in my opinion.
Old Feb 9, 2007 | 11:56 AM
SoCal_T/A's Avatar
ok so that kinda settles that. what bout the throttle body? can i get away using my stock 78mm or do i gotta go bigger?
Old Feb 9, 2007 | 12:19 PM
BlackSVT03's Avatar
That second one is Mighty Mouse's car. Didnt he wreck it? That was the one on the magazine cover right?
Old Feb 9, 2007 | 12:27 PM
amsterdamn's Avatar
Some might disagree, but stock should be sufficient.
Yes, he's working on "MM3" (Turbo WS6). Yes, GM High Tech Performance January 2007 edition.
Old Feb 9, 2007 | 02:50 PM
stevieturbo's Avatar
With boost, stock intake and TB will work perfectly well, and will pose a negligable resistance to you making yor power goals.
An expensive intake like FAST 90/90 would be like throwing money down the toilet, if making power is your aim.
I switched from a stock ported TB and LS6 intake, to a Victory Jnr and 85mm TB, and to be honest, can see little difference in performance between the 2 setups.
Old Feb 9, 2007 | 02:59 PM
dpw41285's Avatar
i am doing what i like to call a budget intake...i traded a stock ls6 for a weiand...going to have it port matched to my heads and have the tb opened up to 85mm. Picked up a 85mm tb from professional products for 170 bucks and i guarantee it will outflow a ls6 with p@p tb. and i only spent 70 more considering its around a 100 for the p@p tb. All very nice components. Plus with 15psi or nitrous in my case i wouldnt want a composite manifold...
Old Feb 9, 2007 | 03:24 PM
It may outflow the the LS6 TB......but can your engine outflow the stock TB in the first place ?
TB Blade and shaft restriction aside.....how big is your intercooler plumbing ? Likely 3"....if so how much restriction is a 75mm TB going to pose when the IC plumbing is 76mm OD ?
Not a huge amount I'd think. An 85mm would pose no restricion at all. It does baffle me as to why some people opt for bigger than that ( on FI applications )
