The ls2 intake is probably the most misunderstood lsx part out there. If you have an ls1 car with headers and a lid(bolt ons), then no, the ls2 isnt what you need. Thats like putting a 850cfm double pumper on a stock 305 for a old chevy truck, Its not gonna make power. Its gonna run like ****. On the other hand If you have a built 408 lq9 that needs to breathe you need an intake that flows more cfm's at its smallest point(throttle opening) Having a 90mm intake on a "built" motor will make more power than an 78mm(ls6) no matter how you look at it. The reason people are not seeing the power gain with the ls2 on stock ls1 motors, is cause the ls2 is engineered for bigger displacement engines. As far as fittment goes, you need a set of high flow aftermarket(pro prod, aeromotive, etc.) for the ls1, and some adapter o-rings to adapt your ls1 injector into the bigger ls2 injector holes (lingenfelter perf.) If you use ls2 rails you will need ls2 injectors and harness pigtails as well, this is to much trouble and costs to much $$. I went through this on my 408 so know how to make it work. Oh and you will also have to extend your map sensor harness. to the front of the intake.
