How fast should i be???
Old Mar 4, 2007 | 10:10 PM
slow_ws6's Avatar
Or could it be because so many miles maybe my tranny is slipping????
Old Mar 5, 2007 | 01:07 PM
Roarin_8's Avatar
Manuals pull better from a roll, you should know that Put in a higher stall converter and you'll pull alot better from a roll. Stock Fbod manuals over here in the east coast trap 106-108 stock.
Old Mar 5, 2007 | 01:13 PM
cfranco98ss's Avatar
i went 13.7@103 my first time at the track and all i have done is a loudmouth cat-back
Old Mar 5, 2007 | 04:01 PM
3.4camaro's Avatar
Originally Posted by Tainted
you need the !drive mod or your car isnt in good running conditon if you onlu pulled a 14.1
first time i went to the track(bone stock) i ran 14.1 @100. its M6, and i didnt know how to launch well(still don't). But I'm happy with the trap speed. I had shitty tires, so i cant really compare to guys with drag radials and slicks and stuff.
Old Mar 5, 2007 | 05:05 PM
Roarin_8's Avatar
Wow man, DA must have sucked for you to trap lower than autos!!!
Old Mar 5, 2007 | 05:17 PM
94'BLKBRD's Avatar
High 11's....Oh wait I didn't notice the SLP smooth bellow,in that case I say MID 10'S!
Old Mar 5, 2007 | 09:43 PM
slow_ws6's Avatar
Haha lol!!!! another question guys!!!! what do yall think would be better richmond 3.73 gears or strange pro street 4.10 gears???? Do yall have any idea what my highway gas mileage be??? and would i notice a big difference???? if so how much of a difference??? Thanks again guys!!!!
Old Mar 5, 2007 | 10:53 PM
SSpdDmon's Avatar
You should talk to Scott (Driveline Solutions - Sponsor). He'll recommend American Axle gears (OEM) and give you good reason...
Old Mar 5, 2007 | 11:01 PM
1slow98Z28's Avatar
i have richmond 373 the wine alot but i get 27 mpg its an auto with full bolt ons on the high way and if i keep off it in the city i get 21 but if not its more like 15
Old Mar 6, 2007 | 08:56 AM
slow_ws6's Avatar
really man my car with the stock 3.23 gets maybe 20 mpg on the highway if im lucky and 10-12 around town!!!! man whats wrong is it cause my car isnt tuned??? and if i put the 4.10s how much would my gas mileage decrease???? by like 5 mpg on the highway or more or less????
Old Mar 6, 2007 | 09:32 AM
slow_ws6's Avatar
Also another question guys with that professional products intake its an 85mm intake what do yall think would be the best throttle body???? I have found 2 different 85mm throttle bodies so far- a BBK 85mm one and a Professional Products 85mm one!!! which do yall think would perform better???? Thanks guys!!!
Old Mar 6, 2007 | 11:43 AM
  #32
Roarin_8's Avatar
As far as gearing, going with shorter gears will help you alot in city driving but on the highway you will lose mpg because you will be turning higher rpms.
There's a discussion about the throttlebodies in the professional products typhoon vs ls6 manifold thread.
Old Mar 6, 2007 | 02:41 PM
  #33
R1LS1's Avatar
just curious where you are located. the track I have access to is at about 5500 feet. I only ran my car once when I first got it and only pulled a 14.3 stock. I was really depressed. But after asking around on here, I realize that I am almost a second slower just because of the altitude up here.
Old Mar 7, 2007 | 09:01 AM
  #34
slow_ws6's Avatar
hey man im in amarillo texas, or about 400 miles east of ABQ!!!!!!
Old Mar 7, 2007 | 04:55 PM
  #35
R1LS1's Avatar
I've been there. You are actually at about the same elevation as me. Our times are close to each other. I wouldn't worry much about it. I own a bike shop and do a lot of business with Exotic cyles there in amarillo. Big dog choppers and stuff.
Old Mar 7, 2007 | 05:59 PM
  #36
Sunset'01Z's Avatar
you dont get the gas mileage you should. try getting your 02's checked out (front) and make sure they are working properly, that should make up for some mileage if they arent. also, make sure you dont have a misfire, that could be bringing your mileage down.
on the gears, i wouldnt even change the ones you have unless you swap to a 12 bolt. 10 bolts arent durable (even though some may argue you can pull a 1.6 60'). you would be wasting money on a doomed rear end. 3.23's arent bad man. even swapping to a 3.73 might net you a tenth since you have a stall converter, so gains would be very minimal anyways.
Old Mar 7, 2007 | 06:08 PM
  #37
gyrene2003's Avatar
yeah, i was thinking of gears to but decided if i ever want to make any REAL power ill just have to get a new rear so why waste money on gears.
Old Mar 7, 2007 | 06:46 PM
  #38
SouthernSilverSpeed's Avatar
with the 4000 stall I have I got down to low 12's
Old Mar 7, 2007 | 09:02 PM
  #39
slow_ws6's Avatar
Really cool man next time ur here you should check out some of the f bodies in amarillo they are pretty sick!!! I know of quite a few ta here running 10's and for sure of one that runs 9's and thats at lubbock dragway so pretty high elevation!!!! And about the rear end even if my car is an a4 it will still break easily???? I know that Texas Speed told me it should hold up even after i put my head and cam package on it but idk!!! They did all the work so far on my car and they said the 10-bolt should hold up in an a4 with heads and cam!! but who knows??
