lifting LS1 with cherry picker....
Old Mar 1, 2011 | 09:20 PM
KSLAYR73's Avatar
Great info. Thanks to all. If I had a shop with a lift, which I don't, I think I would go out the bottom only because I am doing a motor and tranny swap. But, since I don't have those kind of tools at my disposal, I will take the extra time and go out the top. I am going to have to remove all the accesories off my old motor anyway to put on the new one. I would have to say personal preference has some bearing, but having the right tools plays a much bigger role.
Old Mar 1, 2011 | 09:41 PM
Intimidator02SS's Avatar
If you have lift = out the bottom is easier, period.
If you have no lift = out the top because I'm not redneck enough to get my that high off the ground with a ratchet strap or a come-along winch wrapped around the branch of the shade tree in my backyard.
Old Mar 1, 2011 | 09:52 PM
RoidedSS's Avatar
hey! with the redneck comment.....you can use stereo boxes as well lol
Old Mar 3, 2011 | 07:13 AM
shiv15's Avatar
The few times my friends and i have done it cherry picker out the bottom. Lift the car off the motor and trans. And this was in a small garage too. No problems any time weve done it.
Old Mar 3, 2011 | 08:25 AM
KSLAYR73's Avatar
Where do you hook the chains to lift the body? Do you have to remove the front clip?
Old Mar 4, 2011 | 12:10 AM
wickedlsx's Avatar
i pulled my lt1 with tranny from top. had some mounts fabbed up by my dad to bolt to exhaust ports where the headers bolt in and had some rings to put rods on to tilt the motor and tranny however needed. that was first time i ever pulled motor and wasnt that hard could have went by much faster if planned it out better but wastn bad at all
Old Mar 4, 2011 | 10:10 PM
Sykokilla's Avatar
x2 where the hell do you hook up the chain for the motor
and
for when you have to lift the body up?
Old Mar 5, 2011 | 10:18 AM
NBM99SS's Avatar
Out the bottom is the way I prefer. I just wrap a piece of chain around the core support and pick the front end up off the engine/trans.
Old Feb 3, 2012 | 07:17 PM
JasB's Avatar
Default Concerns - Engine out the Top
For a number of reasons, we are about to pull the engine on our 1999 WS6 out the top. The transmission is out and the heads, etc. are also removed. The concern is where to attach the chains/bolts so as to not damage the block.
Any thoughts and/or suggestions would be greatly appreciated.
Thanks,
Jim
Old Feb 3, 2012 | 07:38 PM
S10xGN's Avatar
Thanks,
Jim
Jim,
I've had mine on the hook several times using the four corner valley pan bolt holes with longer bolts and washers...
Old Feb 3, 2012 | 08:22 PM
JasB's Avatar
Russ,
Thanks for your reply. I was just looking at these, but thought they may be too small (diameter) to support the weight. You had no problems using them?
We're talking the valley cover with the knock sensors, right?
Thanks,
Jim
Old Feb 3, 2012 | 08:55 PM
  #32
99 Blue Bird's Avatar
Russ,
Thanks,
Jim
I used the TPIS ls1 motor plate. It uses the valley cover bolts to pull the motor out the top. It goes in place of the valley cover.
Old Feb 3, 2012 | 09:18 PM
  #33
thegroup's Avatar
That's easy (see below) just use 4 grade 8 bolts on the corners is want i did
Old Feb 3, 2012 | 11:40 PM
  #34
JasB's Avatar
Thank you all for helping me with this.
I decided to get the TPIS Plate as we will probably be doing this frequently. We are also putting LS's in two of our 2nd Gens ('72 Camaro & '70 Firebird).
Have a Great Weekend,
Jim
Old Feb 4, 2012 | 03:02 AM
  #35
Track_FC's Avatar
I'll be putting mine in through the tip. Good info in this tread though.
Old Feb 4, 2012 | 06:47 AM
  #36
websdown's Avatar
Helped with a lift out the top a couple of weeks ago used the TPIS plate worked great.Just need the arm on the lift long enough to reach back and not be stopped by the bumper. Two people one to pull the lift forward and one to guide out. This was with no tranny on! Sorry for the late post
Old Feb 5, 2012 | 07:09 PM
  #37
JasB's Avatar
Thanks for the reinforcement on my decision. TPIS Plate.
Jim
Old Jun 14, 2016 | 08:30 PM
  #38
New2LS's Avatar
Originally Posted by Steve Gunn
I used a $15.00 standard lift plate found at any auto parts. I had to key the holes with a dremmel to fit the valley plate holes.
I like this idea...how far were the holes off?
