Is it possible???
Old Mar 16, 2007 | 05:39 PM
'01_z28's Avatar
Default Is it possible???
Is it possible to put on a set of long tube headers w/ a x-pipe leading into a catback system on a '01 z28 without losing ground clearance?
Old Mar 16, 2007 | 06:22 PM
iamsickofitall's Avatar
are you talking about having an x-pipe that goes into a dual in/dual out type muffler? because going into an x-pipe then back into a y-pipe that leads into a single in/dual out muffler would defeat the purpose of having an x-pipe.
bassani makes a true dual style catback with an x-pipe that exits the rear of the car otherwise texas speed makes a true dual system that dumps before the rear axle.
i believe the bassani will give you stock like ground clearance. a little modification will need to be made to fit them to longtubes
Old Mar 17, 2007 | 08:56 AM
'01_z28's Avatar
i was talking about pipes running from the headers into a x-pipe then into two single in in/single out mufflers (flowmaster on-chambers for example) then out the back.
Old Mar 17, 2007 | 09:01 AM
2002BlackSS's Avatar
Sounds like true duals over the axle. There's a lot of examples on here.
Old Mar 19, 2007 | 01:02 AM
Lithium's Avatar
SSU's Drunk Typing Whore
I am pretty sure its possible, just stay away from the SLP headers.
Old Mar 19, 2007 | 01:39 AM
TheBlurLS1's Avatar
That's what she said...
The Sleeper?
I drew this about a year ago, still wish someone would try it.....
Old Mar 19, 2007 | 03:19 AM
Starz T/A 17's Avatar
Originally Posted by TheBlurLS1
The Sleeper?
WOW... thats a good idea, and wouldnt really cost that much either
Old Mar 19, 2007 | 11:53 AM
lsx24's Avatar
The only way you are going to save your ground clearance is 1) don't run any type of muffler, or 2) run a single dual-in dual-out muffler in the stock location. You could also fit a pair of bullets before the tailpipes, but that's hardly sound-deadening. Bassani uses a dual-in dual-out muffler, their dual system works very well. I ran it and gained tons of midrange power, right where I am most of the time in the rpm band.
Old Mar 19, 2007 | 10:38 PM
'01_z28's Avatar
I see what you're saying but i think i'm just gonna do the pacesetter lt's w/ the tsp true duals
