Non-Mandrel Bend Question
Old Mar 21, 2007 | 11:10 AM
Amoretti's Avatar
Default Non-Mandrel Bend Question
I recently purchased a used Borla Ajustable catback to put on the T/A. The over the axle pipe, however, had some serious dents in it that were "beyond repair" according to the muffler shop I took it to. I settled for a non-mandrel bend just to get things welded up for the mean-time.
I'm curious as to how much a non-mandrel bend will hurt exhaust flow, and how much will it affect performance?
And also, is there a place online where I can buy the correct stainless mandrel bent over the axle pipe?
Old Mar 21, 2007 | 11:11 AM
A-Dub's Avatar
You won't notice any difference
Old Mar 21, 2007 | 11:13 AM
Divergent Lightning's Avatar
If the pipe is big enough (3 in) it won't hurt your flow enough for you to notice a difference. Summit sells pre fabricated bends in a variety of degree bends. You can get all you need from them and weld them together. I am sure you could call a sponsor that works directly with pipe bending adn they woul dbe able to help you out as well.
Old Mar 21, 2007 | 11:16 AM
Amoretti's Avatar
Really? No difference? The pipe looked creased and oval shaped, I figured that would limit flow to at least some extent. Hm.
Old Mar 21, 2007 | 01:09 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Its going to limit the flow compared to a mandrel bend. You may of sacrificed a couple hp I am guessin.
Old Mar 21, 2007 | 02:34 PM
A-Dub's Avatar
Sure its not optimal, but you will never notice 2, 3, 5, or even a 10 hp difference on your car.
Old Mar 21, 2007 | 03:00 PM
Amoretti's Avatar
Regardless of whether not I notice it, I'm just curious as to how much power it will rob, if any. 5-10hp would probably be worth having a mandrel bent pipe welded in.
Old Mar 21, 2007 | 04:05 PM
Quik's Avatar
fix it right or dont use it
Old Mar 21, 2007 | 04:09 PM
Amoretti's Avatar
Okay let me just take it all off then.
As stated in the orginal post, I'm looking for the amount of power that is taken away from having a non-mandrel bent pipe. I couldn't care less about your philosophies.
Old Mar 21, 2007 | 04:14 PM
Quik's Avatar
its not worth the amount of money to have a local muffler shop put the pipe in. when you can have a mandel piece for int for same effort just a coupl bucks more.
if you honestly need to ask how much hp then your obvisouly dont care that much
Old Mar 21, 2007 | 04:21 PM
Amoretti's Avatar
Wow. Read my original post.
I'm asking the HP difference out of CURIOUSITY. Did I not make it clear that the non-mandrel bend is temporary? I'm not looking for your opinions, I'm looking for facts. So unless you have some facts to answer my questions, please quit posting in this thread.
Old Mar 21, 2007 | 04:33 PM
silverbandit0996's Avatar
Old Mar 21, 2007 | 05:04 PM
5_02ls1's Avatar
maybe 1hp on topend weve used pipe benders on hi po setups for years they always turn out goodid say its fine unless the man who made it was inexperienced can you get a pic of the pippe
