Header bolt hell!
Old Mar 21, 2007 | 12:14 PM
2000SS1979's Avatar
Default Header bolt hell!
I know this sounds stupid but I can not for the life of me get the header bolts started in. Any tips for this? I was thinking of using some small steel rod to make all the holes line up and then putting in the bolts. Any help is appreciated.
Thanks,
James
Old Mar 21, 2007 | 12:31 PM
Lithium's Avatar
SSU's Drunk Typing Whore
Its easier to have someone hold the header while you get a couple bolts started in. I didnt have anyone to help so I just used a bunjee chord and did my best to prop it up. You will get it, its just a pain in the ***.
Old Mar 21, 2007 | 12:32 PM
VerySlowTA's Avatar
Make sure you have the right bolts first. If you do, try this...
Lift up on the header and hold it in place with one hand. Thread the bolts with the other.
Or, just start the first bolt this way. Then put a jack under the header and use that to hold it in place. That way, both of your hands are free.
Old Mar 21, 2007 | 12:37 PM
senicalj4579's Avatar
lol, i was doing this 1 year ago today. i feel your pain bro. i didnt have anyone helping me and i remember it was a bitch kneeling over in the engine bay holding up the header with one hand trying to thread the bolts in with the other. but i did it and so can you. just have some damn patience lol. try takin a break and going back to it later or something
Old Mar 21, 2007 | 12:50 PM
11 Bravo's Avatar
I used the factory bolts. The tips are pointed so they are much easier to get the thread started.
Old Mar 21, 2007 | 12:52 PM
lastcall190's Avatar
I imagine you have friends... have one hold the header, that's what I did and it worked fine. Best part is he works for beer.
-J
Old Mar 21, 2007 | 01:04 PM
bene's Avatar
Trunion King
Make sure your bolt is clean ie: threads.
Old Mar 21, 2007 | 01:10 PM
Lithium's Avatar
Be careful with tightening them as well...the last thing you want is to have it break off.
Old Mar 21, 2007 | 01:13 PM
bene's Avatar
Trunion King
+1. Make sure you don't get them cross thread too.
Old Mar 21, 2007 | 01:33 PM
FNQUIKWS6's Avatar
use ant-sieze on the bolts.. makes its easier if you ever need to take 'em out.
Old Mar 21, 2007 | 05:27 PM
5_02ls1's Avatar
hold the header with one hand start the bolt with the oeher.
Old Mar 21, 2007 | 05:39 PM
shawn's SS's Avatar
When I installed mine by myself. I took a couple bolts with the same thread and cut the heads off and used them as studs to hold the gasket and the header. I only used two.
Old Mar 21, 2007 | 05:48 PM
WS6 Rampage's Avatar
From: The dirty taint of the country. ...Los Angeles
BOOOM!!............There ya go!
Old Mar 21, 2007 | 09:23 PM
matt94z's Avatar
I held my header in place with a jack stand. Start with the back one then the front. It takes some patience by yourself, but you can do it.
Old Mar 21, 2007 | 09:31 PM
2000SS1979's Avatar
Well I have everything installed now! I just had my brother hold the header from the bottom and I bolted them right up. The car sounds AWSOME with LT's Catted Y and LM1.. Just idling it isnt any louder than the LM1 with stock manifolds. But once you hit the 2500 RPM mark you know you have LT's..
Anyone looking to do a LT install and might have second thoughts. JUST DO IT! It took me about 7 hours total to do the complete header install and remove the AIR & EGR.
Thanks to everyone who helped me out here. I love this FORUM!
James
Old Mar 21, 2007 | 09:40 PM
Congrats man good choice with the cats going with that loudmouth Any sound clips?
-J
Old Mar 22, 2007 | 06:21 AM
2000SS1979's Avatar
-J
It is storming like crazy here today. It is supposed to be a decent day tomorrow I will get some video of the car the.
I went with the cats for two reasons.. rasp and the gas smell. I only drove it for about 5 minutes last night after i got it all put back together. I did not hear any rasp at all. So far i am very happy with the set up. I also did a radio test. I drove at about 55mph in 5th gear and my car was still reasonably quiet I did not have to really crank it up or anything. I was also still able to have a conversation on my cell with my wife. But there is a HUGE sound difference once you hit the 2500RPMish mark. and at WOT it sounds like the world is going to end I love it!
James
Old Mar 23, 2007 | 12:51 AM
green28's Avatar
Congrats on the install. I did as stated above when and used a jack stand to hold up the header. Looks like we need to line them up sometime before you pass me up in the mod department, lol. I'm not living in Plymouth anymore, but I'm still working there so maybe I'll see you around. And BTW is sounds bad *** if you drive WOT under the overpass when you are taking that back road to Lowes.
