Are my rpm's too low???
Old 03-22-2007, 10:12 PM
suburbanlife866's Avatar
Default Are my rpm's too low???
I have all the mods done to my car in my sig, becides the stall, thats yet to go in. My car hasnt been tuned yet....and when I went for a drive today, I noticed that when I am at a stop, my car idles at just above 500 RPM's. Is this too low? You think it will change with my tune? Any imput is greatly appreciated!
Old 03-22-2007, 10:39 PM
connexion2005's Avatar
yes IMO you are to low...typically the ls1 will idle at 1000rpm with a setup like yours or stock...are you getting a ses light?
Old 03-22-2007, 10:45 PM
00slowredz's Avatar
mine idled at 550-600 before the camswap and the tune
question's Avatar
I would say that is def. low for an auto, I wouldn't even expect an M6 to idle quite that low, at least mine does not.
Old 03-22-2007, 10:46 PM
YellowMonster87's Avatar
my last car idled at 650-700 and the current one idles at 600-650
sounds pretty normal to me are you sure its 500 on the dot or could it be closer to 600ish..... 1000 idle is NOT normal unless you have a cam or other reason
Old 03-22-2007, 10:49 PM
00slowredz's Avatar
mine's an auto and it idled at 550-600 STOCK, never pulled a code, nothin. with the cam, it still only idles at like 850-900
Old 03-22-2007, 11:03 PM
haystack71's Avatar
I idle at about 800 rpm with no codes.
Old 03-22-2007, 11:28 PM
That's what she said...
TheBlurLS1's Avatar
The 6-speed cars idle higher than the autos, that seems about right for you. Also keep in mind that your tach may be off a bit. Mine says 1000 rpms when it's idling at 850.
Old 03-22-2007, 11:51 PM
TAwhore's Avatar
hell, mine idels at 450-500 rpm most of the time but i have a A4
Old 03-23-2007, 12:04 AM
Restricted User
Smokin87TA's Avatar
I wouldnt trust the stock tach but stock a4 should idle around 625 and m6 just under 800
Old 03-23-2007, 09:55 AM
Yea the needle is just a tad bit above 500....very slight. So i would say 550 at the MOST. I am getting my stall put in the 16th of april, along with getting a tune for that and the exhaust. Just wanted to make sure everything was normal and that i didnt have anything to worry about. Thanks for the help!
Old 03-23-2007, 10:04 AM
dpw41285's Avatar
mines that low, it was better when i was tuned
Old 03-23-2007, 10:14 AM
SSpdDmon's Avatar
The stock tune in the PCM will tell A4's to idle at 550 for all coolant temps greater than 160*F. If the A/C is on, the desired idle speed is 650 to compensate for the extra load of the compressor.
Old 03-23-2007, 10:24 AM
300bhp/ton's Avatar
yep if you check the hand book an auto should be idling around 625rpm stock.
Old 03-23-2007, 11:33 AM
bjamick's Avatar
Ya thats normal if your in D while sitting at a light it will be just above 500rpm... and if in Neutral i think its like 800 i believe . Your fine so dont sweat it.
Old 03-23-2007, 12:34 PM
FireSilverLullaby's Avatar
yeah mine idles around that, maybe he was joking.
Old 03-23-2007, 02:06 PM
lsx24's Avatar
A4 will idle lower in gear, than in neutral, obviously because of the pull of the converter. That is normal.
Speedmonster185's Avatar
Mine idles in gear at just above 450, but not to 500 with bolt-ons and an A4. It's kinda annoying though because the car vibrates with it right there. If I touch the gas just a bit to get it up slightly about 500 the vibration goes away.
Old 03-23-2007, 03:00 PM
bjamick's Avatar
Raise the idle a tad
Old 03-23-2007, 06:06 PM
Yea same here....when I am in D sitting at a light, My car idles right above 500rpm. And I have the same issue....the car will shake randomly when its idling in D. Its weird
