LS6 intake + throttle body spacer = more plenum volume/power?
14 Second Truck Club
I know throttle body spacers are stupid. But, if you put a smooth bore throttle body spacer, matched to the intake and throttle body bore, would it add power? Seems like it would add slightly more plenum volume and make slightly more power. What do ya'll think?
Originally Posted by Brads LS1 02Z
sounds like a waste to me...
Originally Posted by bayer-z28
I have a link to dyno results from the TB spacer.. I can't access it seeing as it's blocked from work. It gained 6 hp inb an 05 6.0 vette...
You be the judge.
You be the judge.
I doubt it'll add anything tangible on an otherwise stock car. 6hp is well within standard deviation of any run a LSx type engine does.
If you put it in perspective, between the air filter to the intake, you've "added" another section of tubing thereby increasing the distance it has to travel to reach the intake. Look at it this way for LSx engines, does a longer straw increase flow?
