Header Long Tube Length...
Old Apr 12, 2007 | 09:08 AM
Ted J's Avatar
Default Header Long Tube Length...
Does anybody know the different lengths of the tubes on a long tube headers for the F-body? More perferably the ones that are known to work the best on the LS1? I think the set I'm getting used to cut up and fab. up my own set are 1.75" set and I figured I'd check to see about how long I should make the tubes.
Thanks!
Old Apr 13, 2007 | 01:56 PM
Camaro99SS's Avatar
I think QTP makes the longest primary, either them or Kooks. Really though it won't make much difference as they're all close because of the limited space. You will see maybe a 5hp difference on a 600+hp motor. Don't sweat it.
Jason
Camaro99SS's Avatar
sorry, repost
Old Apr 13, 2007 | 02:12 PM
Ted J's Avatar
Jason
Thanks for the info! The SLP's I got are around 32" or so in length, I'll be cutting them up and probably getting close to around 34" or 35" once it's all said and done with after I modify them to fit so that should be in the ball park. I'm going to try to make them as close to equal length as I can but that might be easier said than done. Time will tell if I can pull that off or not.
Old Apr 15, 2007 | 12:51 AM
MarylandSpeed's Avatar
From my experiance, Kooks generally makes the longest primaries and collectors, and their headers fit the LS1 pretty good.
Old Apr 15, 2007 | 09:58 AM
Ted J's Avatar
Anybody know about the size of their primary tubes and how long they are?
