Getting ready to install LS6 intake... Any suggestions?
Old Apr 15, 2007 | 12:37 PM
wild thing's Avatar
Default Getting ready to install LS6 intake... Any suggestions?
My Dad and I are going to be installing an LS6 intake in my 2000 ss. Ive been reading alot of posts and have the write up from ls1howto.com. I was just wondering if yall had any extra pointers and suggestions to make everything go alot smoother. Thanks yall.
Old Apr 15, 2007 | 12:46 PM
2001NBMZ28's Avatar
Just take your time...and don't become a member of the "I broke my oil pressure sensor" club.
Old Apr 15, 2007 | 12:51 PM
wild thing's Avatar
I am going to be extremely careful when it comes to that... I have read countless numbers of posts about people breaking theirs.
Old Apr 15, 2007 | 03:37 PM
ProductionS14's Avatar
It's pretty straightforward, just don't overtorque the bolts when you're tightening it all down.
Old Apr 15, 2007 | 03:40 PM
theblur98ss's Avatar
a little trick i do is pull up the 5 bolts that won't come out and put tape around them to hold them up. Keeps them from dragging on the heads.
Old Apr 15, 2007 | 04:19 PM
kyles2000z's Avatar
plastic wire covers work well too....
be sure when you put the intake on, that none of the wire or sensors are pinched between the heads and the intake, or youl have a massive vaccum leak.
Old Apr 15, 2007 | 04:45 PM
Danny2tek's Avatar
and be careful with the screws that from the cowl
Old Apr 15, 2007 | 05:19 PM
lastcall190's Avatar
Clothespins also work to hold up the bolts. Very easy to compress with just two fingers too because the area under the cowl is very tight at least for me it was. Good luck, IMO you need to really try and break the sensor, I had my intake almost halfway off without undoing the booster line from the manifold, just be mindful and that's that. Got the coolant lines or doing the grinding?
-J
Old Apr 15, 2007 | 06:44 PM
wild thing's Avatar
Im not sure what im going to do about that yet... What do yall recommend doing. I could easily get the lines or I could grind,which one do yall think would be better?
Old Apr 15, 2007 | 06:52 PM
2001NBMZ28's Avatar
Lots of people cut the bottom on the intake - IMO get the pipe/plugs.
Old Apr 15, 2007 | 06:56 PM
wild thing's Avatar
I think im going to go ahead and get the pipe and plugs. I would rather spend a few extra bucks and do it the "right" way.
Are these the only three parts that im going to need?
- 1x 2001+ front coolant pipe - #12568478
- 2x 2001+ rear coolant plugs - #12562788 (Note, you can use a 2nd coolant pipe in place of these plugs if necessary)
Old Apr 15, 2007 | 10:43 PM
Loadre's Avatar
You have to be a tard to break the oil pressure sensor. Just use a hammer and chisel and go to town on the tabs on the bottom of the intake. Just take your time and it's cake.
Old Apr 16, 2007 | 06:00 AM
lovin myls1's Avatar
I bought some 1/4" hose at auto zone,cut into 1" pieces,then sliced down the side so it would slip over bolt and not let it fall back down.Worked great.
I have the coolant lines and block offs as a kit from SLP I was going to sell in the classifieds when I get around to it.If you are interested PM me and I can send a pic tonight and save you a few bucks.
Old Apr 16, 2007 | 10:46 AM
kyles2000z's Avatar
guess me and the other 12,000 folks on here are tards!
Old Apr 21, 2007 | 05:04 PM
Justins00ss's Avatar
Well looks like I joined the club this weekend. Broke the damn sensor right off. Have to wait till monday to get one.
Old Apr 24, 2007 | 11:34 PM
kenp's Avatar
You might want to consider getting the LS6 valley cover that moves the pcv mess out of the valve covers. Thunder racing has a kit with all the stuff you need ready to go.
Old Apr 25, 2007 | 05:13 AM
Bonertee's Avatar
I was thinking the same thing. I did mine this weekend and now I look like I was attacked by a rose bush or something on my arms. Good luck man. Take your time and it will all go smoothly.
Old Apr 25, 2007 | 05:04 PM
B.W.'s Avatar
Get a 8mm ratcheting gear wrench and use rubber bands to hold up the rear 5 bolts on the intake.
Old Apr 25, 2007 | 06:08 PM
1baddls1's Avatar
unless he has to grind chunks off the block for clearance
i refused to do that so i ran a catch can to elimate consumption
looks clean & cheaper
when swapping fuel rails becareful not to nick any of the injector o-rings... bc fuel will SPRAY on start up
Old Apr 25, 2007 | 10:34 PM
98Camarod's Avatar
I resent that. When a pos plastic piece is almost 10 years old and has been heated up and cooled so many times, only time will tell how long it will last. Apparently it was almost 10 years.
On a side note, I gained oil pressure switching oil sending units
I was able to lift my intake right out without doing any clothespin deal or anything. My install was hell in itself, but I assume an ls6 swap would go much easier. It took about 45 mins to get everything off and cleaned.
If you have your pcv stuff this would be a good time to inspect the hoses too. I just capped everything off before I even did the install and put a breather on it, my hoses were broken. I think thats it.
