Under Drive Pulley Installation
Old Mar 20, 2002 | 07:21 PM
eallanboggs's Avatar
Default Under Drive Pulley Installation
Who has experience with the installion of the underdrive pulley (Harmonic Balancer)? The factory shop manual say a special tool is required to "push" the new balancer onto the crank snout and that the bolt installation is a 4 step process. The instructions that ASP sends say "lube shaft and install". That's a big difference in the procedeure. Is a special tool required or can I use the crank bolt to "push" the new balancer onto the crankshaft? Is a new crank bolt required as the factory manual indicates?
Old Mar 20, 2002 | 08:40 PM
Plum Crazy Rob's Avatar
Default Re: Under Drive Pulley Installation
The ASP pulleys have an area of increased bore diameter sufficient to allow it to slip on the end of the crank and get the stock bolt started to pull it on. YOU CAN NOT do this with a stock balancer <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Edit: Replacing the crank bolt is up to you, but they're only like $3.
<small>[ March 20, 2002, 08:42 PM: Message edited by: Plum Crazy Rob ]</small>
Old Mar 20, 2002 | 08:47 PM
FastOrange99Z's Avatar
The factory crank bolt is a Torque-To-Yield bolt. It does stretch when torqued and should be replaced.
Old Mar 21, 2002 | 11:09 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I use new bolts.
The ASP UD pulley will go right on and you can actually thread the bolt a bit...
Old Mar 21, 2002 | 11:27 AM
John02SS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Plum Crazy Rob:
<strong>The ASP pulleys have an area of increased bore diameter sufficient to allow it to slip on the end of the crank and get the stock bolt started to pull it on. YOU CAN NOT do this with a stock balancer <img border="0" title="" alt="[Eek!]" src="gr_eek2.gif" />
Edit: Replacing the crank bolt is up to you, but they're only like $3.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What tool is needed to put stock balancer back on. Just in case I ever need it back on after the ASP install.
Old Mar 21, 2002 | 01:47 PM
Dean98TA's Avatar
I just used a rubber mallet to get the stock pulley back on far enough so that the old crank bolt could grab the threads and take over.
Do NOT hit the pulley on the outer ring part!! Tap it in the center.
Old Mar 27, 2002 | 04:16 PM
NastySSoo's Avatar
I found it very difficult to tap the center of the stock pully without first removing the fans. Use your old bolt to crank the ASP pully on, then replace with new bolt.
Paul
