Replace seal with ASP pulley install?
Old Mar 21, 2002 | 11:29 AM
John02SS's Avatar
Default Replace seal with ASP pulley install?
Is a seal replacement needed when I install my ASP crank pulley? I've heard yes and also heard that it is not needed. Pulley is on the way and want to do it right. Thanks.
Old Mar 21, 2002 | 11:44 AM
Dave Carney's Avatar
Default Re: Replace seal with ASP pulley install?
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by John02SS:
<strong>want to do it right.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">you answered your own question I think.
Old Mar 21, 2002 | 01:32 PM
Jason99T/A's Avatar
I can shift faster than you.
It would be a good idea to replace the crank seal, but it is not absolutely necessary. I have heard of them tearing after trying to remove/reinstall the pulley.
The crank bolt is a 24mm.
Old Mar 21, 2002 | 01:40 PM
Dean98TA's Avatar
Inspect the seal after you take off the old pulley. That's the only way you can tell if it needs to be replaced. If it's not torn or cracked, it's fine.
Or, just do it. It's an extremely cheap part. I can't remember if you need to pull the timing cover to get it out - if I remember right, you do. If so, you need to take off the water pump to get the timing cover off.
<small>[ March 21, 2002, 01:43 PM: Message edited by: Dean98TA ]</small>
Old Mar 21, 2002 | 09:37 PM
Bluestreak's Avatar
If you're going to replace the crank seal, you have to remove the timing cover. I don't see any reason to do this, though.
I don't see how disrupting or removing the stock balancer hurts the crank seal. Hoever... it's only a few more bolts if you wish to inspect the crank seal. Remove the timing cover, and then under a nice, bright light, inspect it for gouges, tears or weak or worn spots. They're only a few dollars. But getting them out of the timing cover is a bitch. There's a special tool for doing that, I used a screwdriver and it took forever.
Old Mar 21, 2002 | 10:00 PM
Red Dragon's Avatar
the pulley seems like it's more trouble than it's worth. I wanna do it but all this recent talk of KR and now replacing the crank seal?? Is it really worth the trouble <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old Mar 22, 2002 | 12:12 AM
Bluestreak's Avatar
A pulley doesn't require anything but a long breaker bar, a six-point socket (I don't remember what size... I think it's 18-mm for the balancer bolt) and a three jaw puller. No seals require replacement. The whole thing shouldn't take you more than 2-3 hours to install, maximum.
Old Mar 22, 2002 | 10:36 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
We've done like seven pulley swaps and have never replaced the crank seal.
Old Mar 22, 2002 | 11:49 AM
John02SS's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Pro Stock John:
<strong>We've done like seven pulley swaps and have never replaced the crank seal.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">That is what I needed to hear! Thanks for the input guys.
Old Mar 25, 2002 | 09:55 AM
John02SS's Avatar
When putting in a new bolt, do you use Loc-tite also. I've heard yes and no, since the new bolt has something already on it. Any input?
Old Mar 25, 2002 | 11:52 AM
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Bluestreak:
<strong>If you're going to replace the crank seal, you have to remove the timing cover. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Wrong. It pops out from the front with a standard seal puller. It's a few minutes and $5, I don't know why anyone even has to think about it, but thats me....
Here, check out the post near the end from "02Hawk"
https://ls1tech.com/ubb/cgi-bin/ulti...;f=24;t=000178
<small>[ March 25, 2002, 11:54 AM: Message edited by: Dave Carney ]</small>
Old Mar 25, 2002 | 11:40 PM
02 'Hawk's Avatar
now we're getting somewhere, so i need a standard seal puller...and what to get the new seal to seat...?
TIA
Chris
Old Mar 26, 2002 | 01:34 AM
Damian's Avatar
LSX Mechanic
I have removed and installed 4 pulley's on my car and never replaced my crank seal.
Old Mar 26, 2002 | 04:05 AM
02 'Hawk's Avatar
mine leaks, wtf i dont have time to dick with it, its going to the dealer tomorrow or wednesday. worst that can happen is they won't cover it and I'll have to pay for it. can't be that much.
they might cover it anyway, who knows. hard to relate a pulley causing and oil seal failure, in my mind anyway.
Old Mar 26, 2002 | 09:07 PM
02 'Hawk's Avatar
going to dealer next monday, enjoyed my visit, seemed like good people, told them about some mods i had, seemed no biggie--none of them are really anyway.
Chris
~stock
