What do you think about this setup
Old Mar 31, 2002 | 09:29 AM
HumpinSS's Avatar
Default What do you think about this setup
1 7/8" Dynatech headers with 3" merge collectors and true dual exhaust. Would I lose or gain any bottom since the pipes are so big. I guess i went 1 7/8" because on the stock motor you can run 1 3/4 but i think that when you started to do head cam and all that other stuff that you would have to ugrade anyway. What other advantages do the 1 7/8 have over the 1 3/4. How would the 1 7/8" perform on a bolt on car only (no cam/heads) maybe an intake manifold.
Curently the car is a 2000 SS with lid 4.10 gears(M6), pulley, flowmaster(that i will lose after the header install) and ported MAF.
Thanks for all the help
Old Apr 1, 2002 | 12:15 AM
WeatherGuy's Avatar
Default Re: What do you think about this setup
That exhaust could be rather big for a stock-cubed car without heads/cam. You could lose low-end (and mid-range??) torque due to lost exhaust flow velocity. That could kill your pulling power on the street.
On the other hand, if you had good heads with a *big* cam and/or a bigger cubed motor, I think that could be a really good setup. I would also want to include an x-pipe in the configuration to help with the flow.
Old Apr 1, 2002 | 12:52 AM
WeatherGuy's Avatar
If you want to see a different opinion to what I have posted, check out this post in this section:
https://ls1tech.com/ubb/cgi-bin/ulti...;f=24;t=000323
