ASR problems (can't turn off or on) light is always on??
Old Apr 22, 2007 | 12:14 PM
shooter's Avatar
Default ASR problems (can't turn off or on) light is always on??
Ok so here is the problem, I had to put my car back to stock again and all is well. She's running like a champ, so I would have to say it's a tune. I don't know about other A4's but mine didn't like the 90/90 at all without a tune anyway. I do have one small problem: for some reason or another ASR isn't engaged nor will it engage. Seems like I disengaged the ASR while I was doing the swap!!! Oh and yes it was working fine before I started all this stuff.
Thank-you in advance for the help!!!
Old Apr 22, 2007 | 07:14 PM
vettenuts's Avatar
What is ASR?
Old Apr 22, 2007 | 07:49 PM
shoemike's Avatar
you should be happy.
the asr is a worthless option on these cars.
Old Apr 22, 2007 | 08:33 PM
cool's Avatar
The same thing happened to a customer of mine at work when he installed an LS6 intake. His car was even setting codes for the ASR motor. He adjusted the cables and says it started working fine after that. it may be worth a shot.
Old Apr 23, 2007 | 08:52 AM
shooter's Avatar
How to you adjust the cable?
Old Apr 23, 2007 | 11:03 AM
senicalj4579's Avatar
any codes or anything else happening with the car?
Old Apr 23, 2007 | 03:09 PM
shooter's Avatar
Hell ya, It's trying die out, and surging up to 3500+ rpm???
Old Apr 23, 2007 | 04:05 PM
smg267's Avatar
Did you ever try driving in the rain? I think its great. I call it the ******* button I turn it off when I want to drive like a retard.
Old Apr 23, 2007 | 07:32 PM
cool's Avatar
From what I can tell, you'd be adjusting the cruise control cable from the cruise servo (which has the cover with ASR molded into it) to the throttle body.
This is from Dealerworld under "cruise control cable adjustment with RPO code NW9"
1. Lift the adjustment lock button up.
2. Pull the cable adjustment slider rearward until all slack is removed from cable, but without opening the throttle.
3. Push down the cable adjustment lock button until it snaps and locks in place.
Important: Ensure that cable is correctly adjusted to avoid excess slack which will cause degraded cruise and traction control performance and inability to achieve wide open throttle. If cables are set too tight the throttle will not fully close.
4.Ensure that the locking tabs are secure on both sides.
Sorry i cannot provide illustrations, they didn't transfer when I copy/pasted this.
Hope this helps. I could be way off.
Old Apr 23, 2007 | 09:16 PM
shooter's Avatar
Thanks brother it's worth a try!!!
Old Apr 23, 2007 | 09:28 PM
shooter's Avatar
Is there anyway you can send me illustrations to my e-mail adcbarrymartin@yahoo.com thank-you
Old Apr 23, 2007 | 10:43 PM
ok,any codes?
Old Apr 24, 2007 | 03:26 AM
Z28_SIMMONS's Avatar
Correct me if I'm wrong, but if you change the tire size from the stock size when doing a tune, it permanently turns the ASR off. That's what my Predator manual says.
Hope that sheds some light.
Old Apr 24, 2007 | 11:42 AM
shooter's Avatar
ok,any codes?
I'm working on getting a code scanner.
Old Apr 24, 2007 | 01:04 PM
purdueranger's Avatar
I have the little SLP box that always turns the ASR off. Never knew the previous owner put that on the car until I mounted up my shift light.
Old Apr 24, 2007 | 07:08 PM
cool's Avatar
youve got mail
