In Tank Fuel Pump Upgrade & External Regulator Kit
Trying to get some feedback on how a package like this would go over with you all through a company I deal with. Neither myself or they are sponsors here, so I don't want to mention names at this point. It would include the in tank pump, sock, witing upgrade, internal regulator bypass, external regulator to mount at the rear wire harness pass through and the proper hose to allow the regulator to be in-line without cutting or splicing. There would also be no extra external wiring needed. It would be a Walbro pump and Aeromotive regulator.
Pricing would be approx $395 with an introductory price of around $350 or so. Dealer pricing can be had also. You can e-mail me or call if you have any questions. Any thoughts you can bring up here would be appreciated.
Thanks,
Mike
What other companies so far so I can compare? I know folks have done some upgrading, but do not know of someone selling a pre-packaged piece for retail.
Thanks so far <img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Mike
Gary
Mike
I just received the "Plug-N-Play" Racetronix setup thru Agostino. Basically a nice intank pump replacement with all new wiring that uses the stock harness plugs. Pretty clean looking! They also made the harnesses so that future upgrades will also plug into it (boost-a-pump, inline, etc..)
https://ls1tech.com/ubb/cgi-bin/ulti...;f=10;t=000412
Tony
Thanks for the info. Seeing as that kit did not have an external adjustable regulator I may be okay here.
Mike
<strong>I checked on the HP this can support and it is 500-550RWHP with stock wiring, which I have seen done, and up to 650+ with stepping up the voltage. Thanks again.
Mike</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">The stock fuel sytem can handle 530+ rwhp, w/ a wet N20 kit. (injectors not being a factor)
Racetronix is working hard to get this system to market soon. Racetronix has many projects under development at this time so it might be a month or two before this kit is ready for market.
These kits will be available though dealers such as ARE.
Jack
Racetronix
<small>[ April 20, 2002, 03:38 AM: Message edited by: Racetronix ]</small>
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
