H Pipe location ideas please...
Old Apr 18, 2002 | 01:25 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default H Pipe location ideas please...
Current: TTS longtubes; 3" duals, ovalized into round; 3" bullet mufflers; turndowns before the axle
I want to add an H pipe to my setup. I know all about the paint/crayon test, but does anyone know generally how far back I should go? I mainly want to quiet the exhaust down.
I am also swapping on different mufflers, Borla XR1's oval.
Old Apr 19, 2002 | 10:14 AM
LS1Tech Co-Founder
Default Re: H Pipe location ideas please...
Anyone know at a minimum how far back I should go?
Old Apr 19, 2002 | 10:20 AM
JC's Avatar
JC
Why are you picking the H over the X? I thought about this, maninly because it would be cheaper to do the H but, then I thought I would loose out on some HP.
Old Apr 19, 2002 | 10:37 AM
LS1Tech Co-Founder
Because I can probably do it on Monday for $30.
Old Apr 19, 2002 | 03:12 PM
UnbelievabLS1's Avatar
I'd say at a minimum 15" from the collector. I've always used 18", and that's worked best for me. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Apr 19, 2002 | 03:31 PM
LS1Tech Co-Founder
Thanks for the response! How did you arrive to those numbers? I'll try that if we weld up the H pipe tomorrow.
Old Apr 19, 2002 | 08:22 PM
Ragtop 99's Avatar
Spend the money and get an X. You got a fricking expensive set-up, don't wimp out here. <img border="0" title="" alt="[Razz]" src="gr_tounge.gif" />
Old Apr 19, 2002 | 11:10 PM
LS1Tech Co-Founder
I cannot do an X without extensively redoing my exhaust, since it's ovalized 3". And I doubt an X is worth significantly more than an H.
Old Apr 20, 2002 | 01:50 AM
JimmyKash's Avatar
its more a quiet thing john with the x pipe
