!Free Mods
Old Apr 17, 2002 | 06:24 PM
  #41
LS1derfull's Avatar
Default Re: !Free Mods
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by gwj:
<strong>Raugh, looking at your page gave me an idea. When you epoxy the TB, what size holes do you have to drill. I'm assuming if you don't drill the holes you will have no idle?
Anybody feel free to step in here.
Gerald</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I drilled 5/16" holes after epoxying my T.B., that worked great, and man does Ported T.B. make a difference!
Old Apr 17, 2002 | 06:46 PM
  #42
LIL SS's Avatar
Moderator
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by 2000 Camaro SS:
<strong>Yah your missing my ram air
<img src="http://communities.msn.com/_Secure/0MwAAAMAQ4JmAQyusDSi8Kw37Y72wm0gElas30XKoxYBaB4NXL K8lsFpnGnxctJ3l!SN0AMoGyMdteDw8K1Cxnw/Pict0012.JPG" alt="" />
It's not like the rest of them this one is fully functional. More photos on my home page.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">When are you going to be selling these?
Old Apr 17, 2002 | 07:52 PM
  #43
2000 Camaro SS's Avatar
LiL SS it really can be made by anyone with medal cutting tools and some heater duct work.
<small>[ April 17, 2002, 07:53 PM: Message edited by: 2000 Camaro SS ]</small>
Old Apr 19, 2002 | 06:39 AM
  #44
01 SS Jay's Avatar
My dumbass would smash that thing up on a curb in about 2 days. I wonder if there could be a lower profile but wider one built that tapers back. Interesting.
Old Apr 19, 2002 | 06:49 AM
  #45
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Jason:
<strong>My dumbass would smash that thing up on a curb in about 2 days. I wonder if there could be a lower profile but wider one built that tapers back. Interesting.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It could be mad to any shap or size! I just pulled this size out of my a$$. (now you know I have a big a$$) The thing about this is you have to remove the nose of the car to make it totally air tight.
Old Apr 21, 2002 | 07:50 PM
  #46
steve's Avatar
moving to the bolt on section
steve frank
Old Apr 22, 2002 | 02:56 PM
  #47
quickWS6's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Patman:
<strong>Raising the coils off the valve covers would keep them cooler, therefore allowing a stronger spark. Sort of like how the C5 guys will remove the cover from the engine to keep the coils from heating up, I believe some of them found a one tenth gain from this change.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What do you use to raise them off the valve covers? Do you completely relocate them? Can you just use a couple of washers to raise them up? TIA
Old Apr 22, 2002 | 03:17 PM
  #48
iwantLS1's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by WILWAXU:
<strong>Remove your air pump, block off the air tubes. It's under the drivers headlight.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">do you have to remove the tubes that comes off the headers also? at which part do you remove them and what can I use to block them off
Old Apr 22, 2002 | 03:25 PM
  #49
WILWAXU's Avatar
You remove the portion that is bolted to the header. The tubes can stay.. that's what the block off plates are for. Many of the sponsors carry the "air tube" block off plates.
<small>[ April 22, 2002, 03:26 PM: Message edited by: WILWAXU ]</small>
Old Apr 24, 2002 | 11:57 PM
  #50
T/A rocker's Avatar
Yes, how do you keep from throwing a code with the air pump removed??
Been trying to get an answer on this, I want to do this mod real bad.
Is the only way to not set an SES is with custom programming or LS1 edit ??
Old Apr 25, 2002 | 11:07 AM
  #51
WILWAXU's Avatar
I'm sure there is a way to trick the computer... but just blocking off the EGR doesn't have any gain. The gain comes from removing the weight of the pump and getting rid of the tubing.
Old Apr 27, 2002 | 03:05 PM
  #52
Cody Brooks's Avatar
on the hollow log mod is there anyway that you could lengthen the primary tubes on the manfold by cutting it and putting short pieces of pipe in between the 2 pieces of manifold i know that this will require modifacations to the exhaust afterwards to make it hook up right but does anyone think it would work and is so how well would it work
