!Free Mods
Old Nov 13, 2001 | 03:42 PM
WILWAXU's Avatar
Default !Free Mods
!=Remove <img src="images/icons/grin.gif" border="0">
-Free Ram-Air (!FRA)
-Fernco coupler mod (3"x3" or 3"x4")
-!Cutout
-Raise Air Box
-Ported Throtte Body
-Torque Trap
-Nostrils cut out on hood (Firebird only)
-Seal Air Box
-Bent metal lip down under air box
-Air Filter Screen / Panty Hose Mod
-Port MAF (!MAF)
-!MAF Screen
-Port & Polish Throttle Body
-Cut EGR (!EGR)
-Timing Tricker (!TT)
-Throttle Body coolant by-pass (!TB)
-!Thermostat
-Short belt (51 inches)
-Grind throttle stop to 4.6 volts
-!A/C belt
-Front tires at 45 psi (warm)
-Hollow Log
-!Collector mod
-!Muffler
-Knock Desensitizer Circuit
-!Air pump
-Fan switch
-!Bellows
-Ram Air Tubes
-!Silencers
Of course weight reduction...
Anything else out there ?
[ November 23, 2001: Message edited by: WILWAXU ]</p>
Old Nov 13, 2001 | 03:46 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Default Re: !Free Mods
Don't forget the !passenger mod. <img src="images/icons/wink.gif" border="0">
Old Nov 13, 2001 | 03:51 PM
WILWAXU's Avatar
That falls under weight reduction <img src="images/icons/wink.gif" border="0">
Old Nov 13, 2001 | 03:56 PM
RyanJ's Avatar
SSU Moderator
lockup switch
nostrils cut in hood (firebird only)
isnt the fernco mod and !bellows the same? you mean baffles out of the hood, right?
Ryan
Old Nov 13, 2001 | 04:19 PM
RyanJ's Avatar
SSU Moderator
pictures of t-stat mod:
Thermostat
Where to put spacer in housing
How t-stat is assembled
example of spacer
where spacer is placed, assembled t-stat
a .090" spacer will give a ~170' temp, and I was thinking an 1/8-inch was ~160'.
Ryan
- I got those from TECH-LS1 by the way. This was originally Steve's thermostat modification.
[ November 13, 2001: Message edited by: RyanJackson ]</p>
Old Nov 13, 2001 | 06:10 PM
Marty's Avatar
On the coupler mod "-Fernco coupler mod (3"x3")"
I used a 3x4". It seemed to fit better. I could not get a 3x3 to fit. Just FYI.
Marty
Old Nov 13, 2001 | 06:34 PM
BIGBOS's Avatar
I got the free ram air!!
and !BACKSEAT
Old Nov 14, 2001 | 02:36 PM
kick_*ss's Avatar
I got the SLP Airbox MOD <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Nov 14, 2001 | 03:27 PM
BIGBOS's Avatar
Thats always a good one... <img src="images/icons/smile.gif" border="0"> <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" /> <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Nov 14, 2001 | 04:53 PM
Retsik's Avatar
John, how exactly did you do your !Air pump mod?
Old Nov 14, 2001 | 04:57 PM
WILWAXU's Avatar
Remove your air pump, block off the air tubes. It's under the drivers headlight.
Old Nov 14, 2001 | 05:18 PM
MIGHTYMOUSE's Avatar
what good does the short belt do you if you are not skipping over any acessories.. or are you skipping the ps pump?
[ November 14, 2001: Message edited by: MIGHTYMOUSE ]</p>
Old Nov 14, 2001 | 05:24 PM
WILWAXU's Avatar
Yep, Dave... you answered your own question <img src="images/icons/wink.gif" border="0">
Old Nov 14, 2001 | 09:30 PM
Hp Joe's Avatar
What exactly does the "Hallow Log" mod do ?
Old Nov 14, 2001 | 11:21 PM
LS1UltraZ's Avatar
Tell me why you would take out your air pump??
Sean
Old Nov 15, 2001 | 12:43 AM
Jason99T/A's Avatar
I can shift faster than you.
[quote]Originally posted by LS1UltraZ:
<strong>Tell me why you would take out your air pump??
Sean</strong><hr></blockquote>
Saves about 7lbs and cleans up the engine compartment quite bit.
Jason
Old Nov 15, 2001 | 01:02 AM
Marty's Avatar
[quote]Originally posted by BlackWS6:
<strong>What exactly does the "Hallow Log" mod do ?</strong><hr></blockquote>
From what I have seen it allows the stock exhaust manifold to flow better by gutting it.
Marty
Old Nov 15, 2001 | 02:27 AM
Patman's Avatar
I've never been a big fan of the throttle body bypass mod, as I feel that since the throttle body doesn't get hot in steady highway driving, or with repeated back to back passes down the strip, that bypassing the coolant through it won't help performance in any way at all.
Old Nov 15, 2001 | 06:13 AM
RyanJ's Avatar
SSU Moderator
i dont know if the tb bypass works performance wise, but there is a temp difference. In my many attempts to put a fernco tube between the tb and maf, ive felt my tb plenty hot even after only driving around little (ambients around here at the time were 85-90+), and after i did the bypass i can cruise or hot rod for an extended amount of time and set my hand on the tb right after i stop and it isnt hot to the touch. maybe its just me. i dont know.
Ryan
Old Nov 15, 2001 | 08:29 AM
SlowZ28's Avatar
Most people will say that the air doesn't touch the tb long enough to get heated by it. I say every little bit helps some how.
Alan
