??HPP3??
Old May 6, 2002 | 03:21 PM
Red Dog's Avatar
Default Re: ??HPP3??
I tried both RFG and Non-RFG tuning, and car was a tenth slower than stock tuning, same day and conditions.
Old May 6, 2002 | 04:36 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
If you have AutoTap it would help out a lot. The reason that some see a loss of power from the HPP3 tuning is because they're getting detonation. The HPP3 can add up to 4 degrees of timing (it did on my '98 T/A with the non-RFG tuning), and if you're running the stock t-stat, lower octane gas, etc., then it will actually hurt you.
__________________
Old May 6, 2002 | 06:31 PM
XFiveLiter's Avatar
Friday night I was messing w/shift points, and just for $hits and giggles I tried the power programming and picked up an honest 1 MPH (new best).
I have the stock t-stat and used 93 oct. gas. Next time I'll try making a few runs and return to stock and see if I slow down or not.
<small>[ May 06, 2002, 06:32 PM: Message edited by: XFiveLiter ]</small>
Old May 6, 2002 | 07:59 PM
NastySSoo's Avatar
My personal exp. with my LT1 was no improvement at the track at all. My track bubbies have seen no improvement in MPH with their LS1s either. Good for turning on fans, gear changes, rev limiter.
Paul
Old May 6, 2002 | 08:17 PM
FatZ28's Avatar
Thx for the info guys.
Old May 7, 2002 | 12:41 AM
FatZ28's Avatar
Default ??HPP3??
Allright the main reason that I am buying the programmer is to fix my speedo. But while I am at it I want to use the power programming for the hp. Some have told me that they have had very good gains with it and some say that they have had no gains with it at all. Can anyone tell me if they picked up any E.T. or mph.
Old May 12, 2002 | 10:16 PM
riddler's Avatar
Veteran: Air Force
I picked up 2 tenths
Old May 12, 2002 | 10:33 PM
FACE's Avatar
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Trevor D:
<strong>If you have AutoTap it would help out a lot. The reason that some see a loss of power from the HPP3 tuning is because they're getting detonation. The HPP3 can add up to 4 degrees of timing (it did on my '98 T/A with the non-RFG tuning), and if you're running the stock t-stat, lower octane gas, etc., then it will actually hurt you.</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">I usually spike my fuel with a couple gallons of 100 to prevent that from happening?
Does anyone know the difference between RFG and non-RFG tuning? Which will give me more power assuming I won't encounter KR?
Old May 13, 2002 | 12:20 AM
Slow Z28's Avatar
i think the RFG/non-rfg stuff is talking about Reformulated gas. Us here in WI have that shitty RFG gas that does nothing but cause problems <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> so if you know you dont' ahve that type of gas, or run a bit of 100 octane, run the non-rfg tuning <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" /> keep an eye on autotap and see how the car is running then too.
Chris
