Pinging
Old May 11, 2002 | 01:58 PM
speed_demon24's Avatar
Default Pinging
I autotapped my car thursday and got 2.8 degrees of KR and I can definatly hear it. I just changed the plugs and wires, so I know its not that. My guess is it is the gas I am buying, it is 93 shell. If it is not the gas what could it be?
Old May 11, 2002 | 02:24 PM
BADZ's Avatar
Moderator
Default Re: Pinging
Make sure and check the wires, the gap on the plugs, Drain your gas tank, Add new gas.
See what happends...
AlonzoVersion 1.0's Avatar
Default Re: Pinging
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by speed_demon24:
<strong>I autotapped my car thursday and got 2.8 degrees of KR and I can definatly hear it. I just changed the plugs and wires, so I know its not that. My guess is it is the gas I am buying, it is 93 shell. If it is not the gas what could it be?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It good be bad gas and or the weather.You dont have a ported maf sensor do you?
Old May 11, 2002 | 02:46 PM
Default Re: Pinging
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by The Booker man:
<strong> </font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by speed_demon24:
<strong>I autotapped my car thursday and got 2.8 degrees of KR and I can definatly hear it. I just changed the plugs and wires, so I know its not that. My guess is it is the gas I am buying, it is 93 shell. If it is not the gas what could it be?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">It good be bad gas and or the weather.You dont have a ported maf sensor do you?</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">No ported MAF, and we did gap each plug at .050 It is in the mid 80's down here. I am going to fill up somewhere else next time and see if that helps.
<small>[ May 11, 2002, 02:47 PM: Message edited by: speed_demon24 ]</small>
Old May 11, 2002 | 06:10 PM
G-LOCK's Avatar
Default Re: Pinging
I hear you Bro! I've been running a ported MAF on my 02 since I bought it without any ping.
The temp gets over 85* and it started pinging so bad, I thought I had a plug fowling out. And the trans was pulling timing hard on shift and a very audible squel could be heard from the tranny also.
I slap the stock MAF on and all is well, no more of the problems mentioned. I hate going backwards on mods but this is one time I didn't mind. All i lost was a slight bit of throttle tip in response. It pulls better and shifts better now.
On my 01, I had to get rid of the TB bypass before the ping would leave.
