Dead Miss After Header Install
Old May 13, 2002 | 04:58 PM
SSleeper's Avatar
Default Dead Miss After Header Install
Since MAC Header Install I have been getting a dead miss (like someone turned the key of and on real fast). Does it real bad when first starting car in the mornings or after it has sat for a while. Makes me think it is temp related but don't know what it could be. Went with ORP and simms with the MAC's. Any Ideas??? <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Old May 13, 2002 | 05:13 PM
Mach Go's Avatar
Default Re: Dead Miss After Header Install
Are you getting an SES light at all???
Jason
Old May 13, 2002 | 05:23 PM
SSleeper's Avatar
NO SES Lights. I have run autotap and adjusted MAFT for LTrims as close to zero as I could get them (0.75 I think) and 02's at WOT to between .89 to .91 (Was running rich at .96 after header install).
Old May 13, 2002 | 05:40 PM
felton316's Avatar
Did you make sure all your plug wires were on all the way?
Old May 13, 2002 | 07:21 PM
wizkid's Avatar
Install Director
Like stated above, check wires first.
Check the sensor next to the #1 plug.
Eric
Old May 13, 2002 | 07:45 PM
rich's Avatar
were the plugs out when you did the install? It is possible that one may have cracked with the removal and install of headers if the plugs were not removed.
Old May 13, 2002 | 07:47 PM
NastySSoo's Avatar
I would try to eliminate plug or wire problem first.
Paul
Old May 13, 2002 | 09:10 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
I agree that I'd check the plugs and wires first. Pull each wire off to check for splits, burns, etc. as well.
__________________
Old May 13, 2002 | 09:31 PM
SSleeper's Avatar
Thanks for the info. I just got in and as soon as the engine cools a little I am going to check plug wires
Old May 13, 2002 | 11:10 PM
SSleeper's Avatar
I have one plug wire that has a small tear in it. Enough so that if you pull on it you can see the wire. I'm going to replace all the plug wires this weekend. Any Suggestions on what to go with? Guess I will replace the plugs while I am at it. Plugs were done at 17,000 miles and I now have 25,000.
Thanks for all the info
Frank
