installing a flame thrower kit and wondering if this will do harm....
With the old distributor systems it was easy. The kill switch stops ALL spark and dumps raw fuel through the engine and out the pipes to be lit by the additional plug(s) in the tail pipe. You just have to rev the engine (to like 5000) and hit the kill switch, the RPM's will fall and you have to get off the switch before the engine stalls. I have no idea how you are going to interrupt the entire ignition system without a fancy relay type circuit. Good luck and post video if you get it working.
Second: the way flame thrower system normally works you would rev the engine and cut the ignition to make the flames come out. This won't work with an injected car because the PCM cuts the fuel while the engine is coasting down to reduce emisions. No fuel = no flames.
Third: the raw fuel in the exhaust will damage the O2 sensors and the cats.
If you want a flame thrower set-up. Go buy a 50 Mercury.
Re'
https://ls1tech.com/forums/showthrea...t=flamethrower
Here you go, two threads on the subject to help you out. Check out 98snakeeaters diagram for info on how he did it.
+1 on seperate coil and propane. You'd probably only need the coil to fire once, anyways. You could use an old neon transformer and stick a spark plug hooked up to it in the exhaust, too.
