New gauge pod and gauges
I'm going to add a triple gauge pillar and I want some suggestions as to which gauges to include. I know for sure that I want air/fuel ratio, which leaves me with two spaces for more. You can see from my sig that I don't have nitrous or forced induction and don't plan to add them in the future, so I have no need to those types of gauges. What are the most beneficial gauges for a naturally aspirated bolt on car that goes over 400 rwhp. My choices are these:
Fuel pressure
Oil pressure
Oil temperature
Transmission temperature
Water temperature
Also, I'm trying to decide between electronic or mechanical gauges. Which are the easiest to install, and would have the least amount of problems once installed?
Thanks in advance for any advice or suggestions.
The third one is personal choice.
a lot of people put a water temp due to the fact that the 99-02 water temp gauges on the cluster just sit at 210
1 guy I know put a vacuum gauge because the cluster already had voltage, water temp, oil pressure.
another I know put trans temp because his transmission was heavily rebuilt and he liked to keep an eye on it.
Personally mine is a vacuum/boost due to the boost
I've installed both mechanical and electrical in a handful of cars and to be honest , neither is really "easier" or "harder". And as long as you take your time and install them right , you shouldn't have a problem with whichever you choose.
For your app I would prob do a fuel pressure, coolant temp, and maybe an oil pressure gauge for the three.
Thanks again for the help.
