header bolt torque
Old Jun 15, 2007 | 10:45 PM
SS4Luck's Avatar
Default header bolt torque
im re installing my headers and am wondering what i should torque the bolts down to. I have pacesetters, gm gaskets, and stage 8 bolts
thanks
Old Jun 16, 2007 | 08:24 AM
HavATampa's Avatar
First pass 11 lb ft., second pass 18 lb ft. Start at the middle and work your way out to the ends evenly. I would drive it for a few weeks and check them again.
Edit: With the Stage 8 bolts you might can get away with re-checking after a few weeks...maybe.
Old Jun 16, 2007 | 10:35 AM
senicalj4579's Avatar
yep,right out of the manual
Old Jun 16, 2007 | 09:38 PM
Ripper415's Avatar
would these numbers be any different if one were re-using stock bolts?
Old Jun 16, 2007 | 10:07 PM
HavATampa's Avatar
Doesn't make a difference if the bolts are used or not.
Old Jun 17, 2007 | 02:10 AM
BLK02TA's Avatar
I reused my stockers today also just did the ole hand torque method. IMO it would be to much of a pain to use a torque wrench on some of the bolts.
Old Nov 20, 2007 | 04:30 PM
Spiewalk's Avatar
Did a search and came up on alot of different opinions on using loc-tite or anti-seize, personally loc-tite makes me think that when you want to get those bolts out one day you may end up breaking the head off of the bolt, IMO. However, I just got the driver side header on by myself with the help of a bucket underneath the header. I had to get a few bolts on then was able to slide the gasket in and remove and reinsert the bolts and tighten. I got them on hand tight and the tightened them up... I don't know if i'm just tired and losing my vision but it kind of seems like I can still see the gasket from the top, should it not be fully sealed? I'll post a pic of later on...
Old Nov 20, 2007 | 06:39 PM
Last C5's Avatar
I error on the side of anti seize and I haven't had anything come loose yet.
