o2 sensors
the Pass side rear is mounted on the tranny crossmember, the drivers side one is on the tranny itself, (sounds like the one you found).
Little clip with a screw through it...
I thought it was, i just put my trans back in and had to reattach it...unless there's 5!?!?
In relation to the flow of the exhaust there is ...
One on each side BEFORE the cat.
One on each side AFTER the cat.
Just keep the ones before the cat and have those plugged in to the extentions. I had to remove mine with a torch.
Ditch the rears and have the codes tuned out.
Drivers side REAR one, is on the tranny.
That's right, for sure.
-J
