Catch Can ~ Yea Or Nay !
Old Jun 28, 2007 | 10:57 PM
Z ROADSTER's Avatar
Default Catch Can ~ Yea Or Nay !
Could someone tell me if it would be advantagous to put one on my 2002 since GM changed up the EGR system & the PC VALVE system on the later models.
Thanks .
Old Jun 29, 2007 | 07:20 AM
vjjack04's Avatar
see topic on same page as your post.
https://ls1tech.com/forums/generation-iv-external-engine/691509-breathers-pcv-bypass-etc.html
Old Jun 29, 2007 | 05:20 PM
zmonsterjb's Avatar
maybe or maybe not, what are your mods and are you burning oil?
Old Jun 29, 2007 | 09:54 PM
INMY01TA's Avatar
Dont need one unless you're getting oil in your intake.
Old Jun 30, 2007 | 09:44 AM
RevGTO's Avatar
Pontiacerator
The EGR system doesn't have anything to do with it - other than making for a nice spot to mount it when you don't have EGR - and the newer PCV system really isn't much more effective than the old. So the only issue is as stated above.
Old Jun 30, 2007 | 10:10 AM
slt200mph's Avatar
Some people have needed to use them because of excess oil in their intake manifold..while others like myself have not needed to use one as I have not had a oil in the intake problem to cure..I use the LS6 valley cover and PCV valve and a breather in the valve cover and this system has worked very well for me.
