Header installation help still
Old Jun 30, 2007 | 04:39 PM
Relapse's Avatar
Default Header installation help still
Well i got the passenger side bolts in, the header is touching the K-member but i'll leave that to the mechanic once i get all this **** finally done, but i've run into another problem, i've jacked the car up enough to get the driver side header vertical on the install and it still will not fit. I've heard people hit the **** out of the wall with a hammer to push it up in that bitch, and i pulled the carpet up and it doesnt look like it would hurt anything, but i'm running out of patience with this project, any suggestions? I've also tried filing down the K-member and i took off the oil filter.
Old Jun 30, 2007 | 04:46 PM
5_02ls1's Avatar
shouldve got pacesetters mine slid right in.....
there is a tab on the drivers side of the block thet somtimes keeps headers from fitting...if thats the prob grind it down
Old Jun 30, 2007 | 09:06 PM
hammerhead's Avatar
Yup, it's probably the casting tab. That's the only thing I had to remove for the driver's side. I cut it off with a small pointed hack saw. A lot of guys use sawzsalls.
Old Jul 1, 2007 | 12:31 AM
lastcall190's Avatar
Sawzall used to cut off my casting tab... Pacesetters literally slid right up after that. Good luck, almost there.
-J
Old Jul 1, 2007 | 12:33 AM
Black02Bird's Avatar
-J
+1........
Old Jul 1, 2007 | 12:43 AM
Relapse's Avatar
i finally got that ****** up in there, a lot of forcing... but i did it, now all i have left is spark plugs wires, steering linkage, and i'll fire her up and hear her purr.. for the moment until i have to get those motor mounts installed .. which will be in a week after i try and pry some rubber up between the k member and the headers and ease the car around all week until i get a mechanic
Old Jul 1, 2007 | 02:33 AM
staringback05's Avatar
its not going to purr....its going to grumble
Old Jul 1, 2007 | 12:30 PM
DYING BREED's Avatar
dude, it will sound sweet, i drove round last week on my open headers and they sounded like a beast!!! on the drivers side i drained the oil and by moving that plug it in great, but the pass side just barely touches the back corner of the k member and vibrates sometimes. i heard a poly mount will take out the play, but if not, im sure you can heat the k member and bang it down a lil bit.... but you will be happy with them
Old Jul 1, 2007 | 12:35 PM
Relapse's Avatar
Yeah i'm just confused right now on what decision i should make. The passenger side header is touching the K-member. Everything else is fine, but... i haven't put some things back on yet, AKA spark plugs.. dipstick, spark wires, 02 sensors steering linkage and battery. And since i don't want to **** with the motor mounts myself, well i just don't have the ***** to with the jack that i have, i'd rather have a mechanic install motor mounts.. but that'd require towing more than likely and a hefty bill... or i can just install all the **** for my headers and see if it's too bad of a rattle and if it is then they would have to take it off at the shop for more of my money, install all that ****, and put the same **** i just installed back on after they're done and charge me hardcore.. Unless there's someone near midland texas that knows wants to do my motor mounts and i'll pay them.. i'm lost haha
Old Jul 1, 2007 | 04:00 PM
scottHMT's Avatar
motor mounts arent that hard with the headers out. I did my headers and motor mounts by myself without help. Granted help would have made it quite a bit easier, but its nothing a bunch of swearing and wrench throwing wont fix. Oh yea, watchout when you jack the engine up, although being covered in powersteering fluid is eeriely comforting.
Old Jul 1, 2007 | 06:00 PM
Poly mounts are hit or miss, every car is different... the fit on mine wasn't even CLOSE. I drove the car up to my brother in law's shop, he's gonna throw them in for a few bucks. I think it may have had to do with one side being a 110k mile stock/shot mount, the other was a brand new poly. Others say it's easy with the headers out, in all honesty I don't see how it would've helped, besides giving a little more room to work. The alignment was what was tricky, not getting all the bolts.
-J
