What do I need to purchase for LT install?
Just as a note, I have a '99 with EGR and AIR... these LT's and ORY will not have provisions for that. I believe I might be getting an intake manifold and throttle body out of the sponsership too, but i'm not totally sure on those yet... if so, the intake manifold will not have EGR provisions either...
so if I get LT's, ORY, IM, and TB... all without the EGR and AIR provisions, then I don't need to buy any plugs/block off plates correct? I can just get rid of all that crap? no problems?
Thanks guys!
o2 extensions are needed....two....
theres not much else if your just doing headers....
Ebay Item Number: 200116329495
EDIT: I would need two of those right? if i got those I wouldn't need extensions?
Also, do you guys think i'd benefit from instally poly motor mounts while in there... for the banging y-pipe issues?
EDIT #2: I could just pick this up right?
proformancemotorsports.com/camaro/exhausts/Headers-Install-Kit-98-03.html
back to the O2 sensors... I have an autometer A/F guage... I've heard I can hook up a wideband O2 sensor to it, would this take place of the front O2's? or would I have the front O2's still on there, and get one additional bung welded on for the wideband to plug into?
Maybe when I get mine on, i'll do that and a how too.
http://cgi.ebay.com/ebaymotors/BOSCH...QQcmdZViewItem
http://www.proformancemotorsports.co...Kit-98-03.html
Yes, those are the o2 you will need. NO, you will not need extensions because the cords are much longer than the camaro sensors. These are for the corvette, and they run a bit colder. Since you will be moving the o2 sensors farther away from the engine they will not get as hot as they were in the stock location. Some people have no problems with the camaro o2 sensors, but I did. I would also much rather buy those sensors, than buy extensions and then later also buy those sensors.
here i got bored....its probably not going to make sticky, but it should help you out a bit
links to ebay for parts that LS1tech sponsors carry is also against forum policy.
I cannot stress that enough.
because of this, i purchased two 24" O2 extensions from Speed Inc. 3 weeks ago (which still haven't even shipped because they're on backorder and i haven't heard a peep from them btw
). when my stock O2's go bad, i'll either get another set of AC delco's or a set of denso oxygen sensors people rave about. if you need new O2 extensions, the pro's on this forum recommend either AC Delco or Denso. I look at it as a challenge... granted if I get time/effort to do so.
