Ugh....
Old Jul 5, 2007 | 12:28 AM
KameleonTransAm's Avatar
Default Ugh....
.....Putting on headers. We took off the AIR and EGR and even the y-pipe. But.....BAM we went to take out the spark plugs and it pulled out the cover with exposed wires. So yeah its broken, how the hell do we get these spark plugs we tried pulling and now I've lost a stock cover Is there a special procedure or something? We did everything so perfect and this easy little stupid thing we screw up. PLEASE HELP
Old Jul 5, 2007 | 01:13 AM
staringback05's Avatar
i guess your talking about stripping a spark plug wire...not sure....but i did this also its typical if you havent put dia-letic grease on before you put them on....
needle nose pliers work well and just get another set of wires....i had some msds standing by
Old Jul 6, 2007 | 12:36 AM
HavATampa's Avatar
Been there done that with the stock plug wires. Make sure you twist back and forth a few times at the boot before pulling. I see there are several threads in the For Sale forum selling used stock plug wires. Here's one thread:
https://ls1tech.com/forums/lsx-parts-sale/729130-cleaning-out-garage.html
Old Jul 6, 2007 | 01:13 AM
Oh thank you for your responses, but luckily my local Advanced Auto had a set of 8 of our exact stock wires (which shocked the hell out of me). Thanks Again.
Old Jul 6, 2007 | 09:57 AM
bczee's Avatar
Remember to use the grease on the plug / boots, twist before pulling and look into one of them simple tools that just looks like a flat metal/rubber coated hook to reach in to the end of the boot to pull from the end of the boot.
Old Jul 6, 2007 | 10:38 PM
mnypitZ's Avatar
Yeah you are lucky. I stuck a rag over the EGR hole when we removed it so we wouldnt drop dirt inside. YOU GUESSED IT, we forgot to plug the hole and forgot to remove the rag and started the car up. The rag dissapeared and we bent valves. The GOOD news was that afterwards I "had" to buy new heads. I think the wife may be starting to catch on..............................
Old Jul 7, 2007 | 12:57 AM
ThaBirdMan's Avatar
lucky
Old Jul 7, 2007 | 01:00 PM
Hah sucks about the EGR thing, I just left mine open during the install. Go not caring!! But yeah everything went well, the installation is complete and my car is now EGR and AIR-less with long tubes
 Michael S. Palmer
Old Jul 7, 2007 | 01:09 PM
mnypitZ's Avatar
Great to hear that. I just finished up the LS6 valley pan and LS6 intake. Didnt get any rags sucked in this time.
