Stage 8 Header Bolts...
Old Jul 8, 2007 | 10:33 PM
Tainted's Avatar
well thats a good enough excuse. if it gives you peave of mind then it was worth the $17 extra. ive been down that peace of mind route already with rod bolts
Old Jul 15, 2007 | 09:34 PM
RacerScott's Avatar
Originally Posted by Tainted
I got mine from Speed inc and im happy with'em. I can get pcis of the clips on my motor if you want but I can't guarentee you it will be today.
The more expensive set has enough bolts for both sides im guessing?
Tainted, I installed pacesetters today and stage 8 lockers, install went great, 0 problems. I have a question about the lockers on the bolts. The seem loose after I put the e-clip on and are able to rattle around. I have the pointed lockers that came with the ls1 stage 8 kit, I have a coupe lockers like yours but I suppose those are for the bolts without a header tube next to them. Is this normal and do they make rattling sounds when the engine is running, I havent started my engine yet, i'm doing a ls6 intake too that I will be wraping up tomarrow.
Old Jul 15, 2007 | 11:06 PM
Tainted's Avatar
yes they have a little bit of room, but if you had no room how would you ever get them off? I guarentee you wont hear them rattle when you get the car running
