can you solder O2 sensor wires?
Old Jul 7, 2007 | 01:36 PM
30th t/a's Avatar
Default can you solder O2 sensor wires?
if your melts the wires coming out of the harness, and you cut them out and solder new wire in?
Old Jul 7, 2007 | 01:59 PM
juicedls1's Avatar
Yep shouldnt hurt any thing, i just used some gm style heat shrink butt connectors on mine and they work great! Use your preference!!!
Old Jul 7, 2007 | 02:04 PM
30th t/a's Avatar
damn cause I just did and my car is still slightly bucking while cruising. its annoying as hell.
Old Jul 7, 2007 | 03:37 PM
bczee's Avatar
plug in a scanner and see if you are getting a good reading from the O2 sensor and that it change as you would expect or jumping up and down...
Old Jul 7, 2007 | 03:45 PM
99NMB's Avatar
I tryed to extend the factory o2's when i first installed my headers. They started giving problems almost immediatly after, they kept giving me low voltage codes, i ended up just going down to the autopart store and getting Bosch 13111's. The Bosch 13111's are Corvette rear o2's, alot of guys use them...
Old Jul 7, 2007 | 03:49 PM
NHRAMAN's Avatar
From: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Cool
13111 VETTE REARS HERE...Great O2's.
Old Jul 7, 2007 | 03:53 PM
Soul TKR's Avatar
do you guys have the GM Part number for the Bosch 13111's?
Old Jul 7, 2007 | 04:13 PM
1FSTLS1's Avatar
Butt conectors all the way. Just heat shrink em
Old Jul 27, 2007 | 02:04 PM
xBROKEx's Avatar
you could have had a cold solder joint that could cause some connectivity issues
Old Jul 27, 2007 | 02:05 PM
brad8266's Avatar
I extended a set before and they worked fine for a long time. When i swapped them the last time though I just went with the 13111's, they come with long wires.
Old Jul 27, 2007 | 04:40 PM
5_02ls1's Avatar
i used the shrink connectors and im gettin low voltage codes and a rich idle.....i ordered a set of extensions and im hoping the new ones do fine......
