"X" vs "H" Pipe Discussion
Old May 11, 2003 | 07:15 PM
mikey's Avatar
LS1TECH Sponsor
Default "X" vs "H" Pipe Discussion
Ok guys, I am about to test an X pipe vs an H pipe on a test car. The headers are a set of Kooks 1-7/8" merge (3"). Give me your opinions and well see who get's it right...
Mikey
Old May 11, 2003 | 08:21 PM
dug's Avatar
dug
Default Re:
The Xpipe will make more power everywhere. Im more curious about power differences with the xpipe vs a 3" to 4" ycollector.
Old May 11, 2003 | 09:52 PM
Jpr5690's Avatar
Default Re:
i think h will be better giving they are simlar diameter pipes cause it just seems that the h will allow for the flow to be even without making the exaust flow tuburlant(IMO)
Old May 11, 2003 | 11:40 PM
DONAIMIAN's Avatar
Default Re:
I saw about a year ago where they did this on a mustang using X and H pipes from the same company so the cross over would be in the same place and the H pipe gave it a deeper tone, while the X made it sound more nass car. Also they said that the X favored the top end while the H favored the bottom end. The H gave it more TQ on the bottom while the X game it more hp up top.
Old May 12, 2003 | 03:45 AM
red90cobra's Avatar
Default Re:
Does Kooks have a website or is there somewhere I can look up those headers? I hear there good headers. Just haven't read anything bout them. Thanks.
Old May 12, 2003 | 06:12 AM
mikey's Avatar
LS1TECH Sponsor
Default Re:
They are a sponsor here. We also sell their products.
Mikey
Old May 12, 2003 | 10:31 AM
TheDogofWar's Avatar
Default Re:
Think I know the article. CarCraft wasn't it that did it? It was kinda scewed though if I remember correctly. They had an elaborate pipe diam config for the X-Pipe I think.
Location is going to be the biggest thing I'm sure. I've always been taught that it should be at the hottest area.
Overall I expect the X-Pipe to come out ahead, especially on top end.
Old May 12, 2003 | 08:56 PM
da zman's Avatar
Default Re:
what about NO-pipe just straight through??
mike
Old May 12, 2003 | 10:41 PM
RB185AFM's Avatar
Default Re:
I think an x pipe will out perform straight pipe. At least it did on my 98 Cobra. Though it was not much. I picked up about 2hp when I went from straight to x.
Old May 13, 2003 | 09:07 PM
GeorgeC's Avatar
Default Re:
Mikey, I look forward to reading about your results...
I'm contemplating a future change to a set of Kooks headers, a 3.5" X-pipe, and more subtle mufflers than the Flowmaster 1-chambers I have now.
Be sure to keep us updated!
Old May 13, 2003 | 10:52 PM
DONAIMIAN's Avatar
Default Re:
And another thing that goes to show that the X-pipe puts out more on the top end is that NASS cars run then and then never see anything below 8000rpm in a race, if even that
Old May 14, 2003 | 11:37 PM
John B's Avatar
Moderator
Default Re:
The "X" will spank the "H" pipe by a few HP. Just make sure the exhaust pipe is correctly sized!
Old May 15, 2003 | 06:31 AM
highgmc's Avatar
Default Re:
I have the 1 7/8" stepped kooks and the rest of my exhaust will consist of an x pipe, mufflers and dumps before the axle.
Old May 15, 2003 | 09:02 AM
Speedfreaks101's Avatar
Default Re:
I say that the X pipe will definitely win up top but the cam profile will dictate when the X pipe starts to out perform the H pipe. I personally think that in order to really prove which one is better then you would need a reverse split cam.
I am curious if anyone has ever used termination boxes with an X pipe? I have thought it over and I am not sure if there would be any benefit because the X pipe essentially increases the exhaust volume like a termination box but it also allows the exhaust to use the negative pressure waves from each cylinder bank. Just curious.
Old May 15, 2003 | 08:24 PM
Ragtop 99's Avatar
Default Re:
I'd vote for a well made X pipe to beat an H. A cheap X pipe may not.
