I have a serious problem,,,, help please
This is a 6 speed car.
Help please
Good luck,
Pete
Can you tell me which wire is the one that controls the emg break?
break <> brake
Someone somewhere has messed with your wiring. The emergency brake circuit is supposed to enable hatch release, and as I recall the DRL circuit. It is a black wire, just under the E-brake.
Does the car restart with the brake off, does it crank over at all?. Start by pulling the fuse for the headlights, see if you still have the problem.
So your saying look for a black wire underneath the console somewhere?
DaddySS: when the break is down i cannot restart the car.
when you put it all the way down it dies,have you tried in the middle, and all the way down to the last click but now all the way down.
trying to see if it is lights related or short ( I think it is a short either way BTW) like someone
had mentioned before about the head or DRL lights.
Has someone hacked on your wiring?
It is not a *break*, that is what is wrong with your wiring. I guess I should be quiet and just go shopping for a pear of shoes.
My black wire was tapped into underneath the steering wheel, but that should effect anything because it wasnt cut.
