cruise control
BTW that Montery Maroon Metallic... best color the Camaro ever came in. I almost got one of those. Should have.
The unit will bolt onto the outer side of the drivers frame rail. it sits in a bucket looking bracket.
you need a 10 mm rachet. loosen off the flap door on the drivers side. located in front of the wheel. it is just two bolts.
lower that flap and you will see 2 holes in the middle of the frame rail. the electrical connector has always been a pain to plug in for me.
i loosened all the plastic further by taking out the 10mm bolts from the wheel well to half way up the front of the car and then pulled down on the plastic to unclip a clip near the condensor. gets all that mess out of the way.
then i just snaked the cruise control cable up from the frame rail area and the long way around the brake booser. the cable will have a silver clip that goes on the booster. then just follow the curve of ur factory throttle cable to the TB or TCS motor. Are you ASR or not?
